Great operating system but small Problems
Hey Ho @All
I like your operating system and also have a license for 3 years.But there are minor problems.
From other forums I know there is the right and the wrong way,to talk to you about / tell it.
as would be correct, there is a policy?
sorry for my bad english, I speak German and use the translator.
Best regards
German:
Ich glaub du kannst sagen was du willst :wink:
Was hast du denn für Probleme mit Rockstor?
Gruß
Mark
Hi @12Matze21 Matthias and welcome to Rockstor community :slight_smile: <- (Rockstor hasn’t a specific policy about questions / comments /etc etc, just be kind and ask what you want)
Please tell us what you think about Rockstor and ask whatever you want to know :slight_smile:
Flyer
Thank you for your answers
Pictures say more than words…
Problem 1:
After Update
system starts, but what does this error message?
Problem 2:
Samba share
in my system is a hard drive with 3 terabyte memory, this is enabled via samba.
after each reboot the release is not yet displayed correctly.
/Externe 6,67GB
that is not right
So I update every time the release of hand
Then it’s true
is it possible to solve this?
I hope I could express myself clear
Mfg
Hi @12Matze21, I assume you’re using a Rockstor Rock-on, am I right???
Just asking this because I’m not a Rock-ons guru :slight_smile:
Flyer
correct, Plex Media Server is installed,and running.
but also has problems with the samba release…
Ok, asking to @suman and @phillxnet because i think it’s 90% related to Plex and, as I told you, I’m not so good on Rock-ons (never used)
Flyer
Ok,
how do I get her attention, a message I can not send…
Adding suman and phillxnet names to my post i notified them so you don’t need to send any private message :slight_smile: (not “her”, they are both male)
Flyer
