Hardware Error during boot
I’m running an ASRock J4205-ITX machine with 8 GB RAM. BIOS is updated to the latest one. Only when rebooting I find this errors which might be a problem that CPU is not fully supported by the kernel? Do I have to wait until the next kernel or microcode update? Machine runs without Problems, so perhaps I can ignore these errors?
Output of mcelog:
mcelog: Family 6 Model 5c CPU: only decoding architectural errors
Hardware event. This is not a software error.
MCE 0
CPU 0 BANK 4
ADDR fef13b80
TIME 1499855972 Wed Jul 12 12:39:32 2017
MCG status:
MCi status:
Uncorrected error
MCi_ADDR register valid
Processor context corrupt
MCA: Internal unclassified error: 408
STATUS a600000000020408 MCGSTATUS 0
MCGCAP c07 APICID 0 SOCKETID 0
CPUID Vendor Intel Family 6 Model 92
MCE 1
CPU 0 BANK 4
ADDR fef13b80
TIME 1499919481 Thu Jul 13 06:18:01 2017
MCG status:
MCi status:
Uncorrected error
MCE 2
CPU 0 BANK 4
ADDR fef13b80
TIME 1500005881 Fri Jul 14 06:18:01 2017
MCG status:
MCi status:
Uncorrected error
mcelog: warning: 24 bytes ignored in each record
mcelog: consider an update
uname -a
Linux nas 4.10.6-1.el7.elrepo.x86_64
lspci
00:00.0 Host bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Host Bridge (rev 0b)
00:02.0 VGA compatible controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Integrated Graphics Controller (rev 0b)
00:0e.0 Audio device: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Audio Cluster (rev 0b)
00:0f.0 Communication controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Trusted Execution Engine (rev 0b)
00:12.0 SATA controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SATA AHCI Controller (rev 0b)
00:13.0 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #1 (rev fb)
00:13.1 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #2 (rev fb)
00:13.2 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #3 (rev fb)
00:13.3 PCI bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series PCI Express Port A #4 (rev fb)
00:15.0 USB controller: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series USB xHCI (rev 0b)
00:1f.0 ISA bridge: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series Low Pin Count Interface (rev 0b)
00:1f.1 SMBus: Intel Corporation Atom/Celeron/Pentium Processor N4200/N3350/E3900 Series SMBus Controller (rev 0b)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 11)
03:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
Any suggestions?
Thanks in advance
Uli
Hi Uli,
I assume you’ve checked on the Intel site, too? I saw this thread:
https://software.intel.com/en-us/forums/intel-firmware-engine/topic/603829
which doesn’t exactly cover your error code, but it seems that they sometimes have either a solution or can help you with that. It does not look like your issue is a kernel related one.
Sorry, if you’ve already researched in that direction and had no success …
Hi Dan,
thanx for posting the link.
I’ve already researched in that direction and have found other similar Topics concerning this error. But none of them fits to my issue.
I think I have to wait for a new Bios or microcode. And I agree with you that it’s not a kernel related one. Perhaps it’s a minor issue, because System runs without any Problems.
Uli
@Hooverdan for the suggestion I will check and hope it helps.
