Installed Home Assistant docker, worked perfect! Did some configuring (well trying it out, to see if I can exchange it for all the apps and the spagetti type of configuring IOT’s and other stuff)… I think this is great so I will continue to use this one…
Then I got interested in Node-RED, and tried to install it also (different, share, different port)… But as soon as it was installed Home Assistant stopped working and Node-RED started (docker service?) but was not available… so neither was working until I uninstalled Node-RED, then Home Assistant started again…
There should be no conflict for the 2, unless you have something like for example overlapping ports somewhere (which by default I don’t think they would, even with Home assistant running in host networking mode). But I only run HA so I wouldn’t really know.
Did you happen to check the logs for any hints using the docker logs <container name>?
If not, Is that something you could try (possibly temporarily making home assistant not work)?
If you stop (but not uninstall) the Node-RED Rockon, does HA work again?
Sorry for the delay! No ports that clashed, (I uninstalled Node-red, but could try it again) but as far as I remember I don’t think HA container ran even if I stopped Node-red container.
Did not check any logs (I’m Unix/Linux neewbie I will try it again and check the logs for any hints for sure!
Ok, had to shutdown my Rockstor installation for awhile, so I can not remember what I did but I think i just uninstalled HA and Node-red (a couple of times) and voila it worked… I can not now remember what did the trick or why. But both runs fine now… thanks for the help!
