Hello,
I am trying to install the kernel headers:
sudo yum install kernel-headers
- base: mirror.jgotteswinter.com
- epel: mirrors.telianet.dk
- extras: mirror.eu.oneandone.net
- updates: ftp.hosteurope.de
Resolving Dependencies
→ Running transaction check
—> Package kernel-headers.x86_64 0:3.10.0-327.el7 will be installed
→ Processing Conflict: kernel-ml-headers-4.3.3-1.el7.elrepo.x86_64 conflicts kernel-headers < 4.3.3-1.el7.elrepo
→ Restarting Dependency Resolution with new changes.
—> Package kernel-ml-headers.x86_64 0:4.3.3-1.el7.elrepo will be updated
—> Package kernel-ml-headers.x86_64 0:4.4.3-1.el7.elrepo will be an update
→ Processing Conflict: kernel-ml-headers-4.4.3-1.el7.elrepo.x86_64 conflicts kernel-headers < 4.4.3-1.el7.elrepo
→ Finished Dependency Resolution
Error: kernel-ml-headers conflicts with kernel-headers-3.10.0-327.el7.x86_64
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
Both suggestions do not work.
Can someone hint, how to install the kernel-headers?
I need to build a kernel module for a dvb-card.
Regards,
Hendrik
