How to add https to jellyfin?
Hello,
I installed jellyfin on rock-on.It’s can use https.But it’s use letsencrypt to add it.How to add letsencrypt ssl to jellyfin?
@akong, the Jellyfin provides some instructions on how to add it when Jellyfin is running in a docker container (which is what the Rockon represents). Take a look here:
https://jellyfin.org/docs/general/networking/letsencrypt.html#lets-encrypt-and-docker
We currently don’t have a swag Rockon, so you can either use the command line and perform the installation/integration, or, which would be great of course, try your hand at introducing linuxserver’s swag container as a Rockon. Since we have quite a few examples of other Rockons on github, this could be straightforward. Check it out here for an explanation on how to create a corresponding json file:
