File “/opt/rockstor/src/rockstor/storageadmin/views/disk.py”, line 377, in post
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/disk.py”, line 322, in _update_disk_state
p.uuid = btrfs_uuid(dob.name)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 1055, in btrfs_uuid
[BTRFS, ‘filesystem’, ‘show’, ‘/dev/disk/by-id/%s’ % disk])
CommandException: Error running a command. cmd = /sbin/btrfs filesystem show /dev/disk/by-id/sda3. rc = 1. stdout = [’’]. stderr = [‘ERROR: not a valid btrfs filesystem: /dev/disk/by-id/sda3’, ‘’]
@echoxalpha Welcome to the Rockstor community
and @Haioken thanks for the fine suggestions here.
This can happen when the system drive has no serial, such as when Rockstor is running within a VM with insufficient configuration re passing through / providing unique serial numbers for disks ie such as real disks have.
