I have a personal NAS with ASRock C2550D4I motherboard. It got three network jack (one for admin and the other two are regular network). I was toying with network bonding using config files. I gave up on it because the bonded interface only has 100Mb connection. Rockstor now has this error message:
Error!
update or delete on table "storageadmin_networkconnection"
violates foreign key constraint “connection_id_refs_id_61d432b3” on
table “storageadmin_ethernetconnection"
DETAIL: Key (id)=(1) is still referenced from table
"storageadmin_ethernetconnection”.
If you need more help on this issue, email us at support@rockstor.com with the following information:
The error message: "update or delete on table
“storageadmin_networkconnection” violates foreign key constraint
"connection_id_refs_id_61d432b3" on table
"storageadmin_ethernetconnection"
"storageadmin_ethernetconnection".
"A step by step description of the actions leading up to the error.Download the tarred and zipped server logs by clicking here, and attach it to the email.
What can I do to clean up the db?
Thanks
