I’m new to using rock stor and would like to install this to get my ssl certificate so i can access the mobile app. can anyone can provide a guid on how to do this?
For which Rockon are you interested in using this?
The challenge here is that this docker-mod from linuxserver.io will not work with Rockon definitions on linuxserver based docker images as they are today, because these parameters need to be part of the Rockon definition itself to be considered during the install.
Your only option if you want to go down that path is to install the relevant docker linuxserver-based directly (including the docker mod parameters) using the docker engine (i.e. using the command line).
