Hello,
I’m putting this in trouble shooting because I’m not sure if there are some housekeeping functions that didn’t run as expected leading to this.
Just came back from 3 weeks away and couldn’t access my Samba shares, tried logging into the gui and got the Rockstor banner, but an error screen where the dashboard should have been. I accessed it via VPN several time while I was gone, so I think the failure is recent. Rebooted from CLI and when I tried to get to the GUI, got an unable to connect error. Did a shutdown from CLI and powered back up while watching the local monitor. Noticed about 6 boot options during the boot process and then boot failed with a disk full option. Back to the CLI to determine what was full, and got this:
[root@jonesville ~]# df
Filesystem 1K-blocks Used Available Use% Mounted on
devtmpfs 8191912 0 8191912 0% /dev
tmpfs 8202392 0 8202392 0% /dev/shm
tmpfs 8202392 8636 8193756 1% /run
tmpfs 8202392 0 8202392 0% /sys/fs/cgroup
/dev/sda3 25868288 25714676 172 100% /
tmpfs 8202392 4 8202388 1% /tmp
/dev/sda3 25868288 25714676 172 100% /home
/dev/sda1 487634 248524 209414 55% /boot
tmpfs 1640480 0 1640480 0% /run/user/0
[root@jonesville /]# fdisk -l
Disk /dev/sda: 30.0 GB, 30016659456 bytes, 58626288 sectors
Units = sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk label type: dos
Disk identifier: 0x00000ff4
Device Boot Start End Blocks Id System
/dev/sda1 * 2048 1026047 512000 83 Linux
/dev/sda2 1026048 6889471 2931712 82 Linux swap / Solaris
/dev/sda3 6889472 58626047 25868288 83 Linux
Tried a Yum Clean All with the following results:
[root@jonesville /]# yum clean all
error: rpmdb: BDB0113 Thread/process 6258/140430441711424 failed: BDB1507 Thread died in Berkeley DB library
error: db5 error(-30973) from dbenv->failchk: BDB0087 DB_RUNRECOVERY: Fatal error, run database recovery
error: cannot open Packages index using db5 - (-30973)
error: cannot open Packages database in /var/lib/rpm
CRITICAL:yum.main:
Error: rpmdb open failed
Before I try a database recovery I think I need to free up some space and try the clean again. I assume there are some log files I should be able to delete, but I’d like some advice so I don’t delete the wrong files by mistake.
Finally, is there a service that should have been running to prevent this by default, or did I miss a setup step to set one up. Thanks in advance for help, Del
I found a bunch of files in a usr older that I was able to kill off and everything booted and I’m back to normal. Now the lingering question is what filled up and why? Is there a something I should check to prevent a recurance?
Thanks again.
