Idea for Dashboard extension / Top 10 running processes sorted per CPU usage from command "ps"
just an idea…
Maybe some else had it before, but I think it would be nice if we could extend the dashboard by an extra screen/window (enabled with a simple check box) that shows the top 10 running processes sorted by their CPU usage (extracting simply from ps -aux | less). So having this information also on the Web UI not only via the terminal :slight_smile:
What do you think @suman @Flyer?
Thanks,
Roland
:wink:
Will have it, it’s a promise, actually “playing” with a major feature: custom tasks via WebUI :slight_smile:
Mirko
