@coleberhorst Welcome to the Rockstor community forum.
Your quoted max speed of 11MB/sec is suspiciously close to 100Mbit lan type speeds so it might be worth checking to see if the lan card has been switched to it’s 1Gbit mode properly. So I’d suggest you first double check the effective network speed via something like iperf.
On the Rockstor machine execute the following to install the iperf tool:
yum install iperf
then run this newly installed tool in it’s server mode (via the ‘-s’ switch):
iperf -s
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
this will then sit there waiting for a client machine to connect and perform tests against it.
(Ctrl + c to close this program)
So then you need the same program installed on a client machine on the same network:
ie in my case a Fedora 24 machine and run it in client mode( via “-c” switch):
The ‘-i 2’ means report every 2 seconds and is optional.
iperf -i 2 -c cube.lan
Client connecting to cube.lan, TCP port 5001
TCP window size: 85.0 KByte (default)
[ 3] local 192.168.1.110 port 39888 connected with 192.168.1.142 port 5001
[ ID] Interval Transfer Bandwidth
[ 3] 0.0- 2.0 sec 224 MBytes 941 Mbits/sec
[ 3] 2.0- 4.0 sec 224 MBytes 941 Mbits/sec
[ 3] 4.0- 6.0 sec 224 MBytes 942 Mbits/sec
[ 3] 6.0- 8.0 sec 225 MBytes 942 Mbits/sec
[ 3] 8.0-10.0 sec 224 MBytes 942 Mbits/sec
[ 3] 0.0-10.0 sec 1.10 GBytes 941 Mbits/sec
At least then you can test the effective network speed to rule that element out.
If you paste your results into this thread as you go then it gives others more info to help diagnose where the bottle neck might be.
As for your sata pci-express x1 cards they appear to be based on the Asmedia 1061 SATA host controller chip. I have something similar here akin to what is found in the Rockstor Shop on the mSATA adapter. Although both are actually based on the ASM1062 chip not the ASM1061 as a quick look-up of your card suggested:
ie:
lspci | grep SATA
00:13.0 SATA controller: Intel Corporation Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series SATA Controller (rev 21)
01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
04:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
And the throughput here to an attached mSATA card is:
hdparm -tT /dev/disk/by-id/ata-KINGSTON_SMS200S330G_50026B724C085CD1:
Timing cached reads: 2826 MB in 2.00 seconds = 1413.63 MB/sec
Timing buffered disk reads: 528 MB in 3.00 seconds = 175.77 MB/sec
Timing cached reads: 2848 MB in 2.00 seconds = 1424.35 MB/sec
Timing buffered disk reads: 552 MB in 3.00 seconds = 183.95 MB/sec
Note the above is also the system drive so may be in use during the test.
And testing both the built in N3700 SATA controller (2 ports) and the one built into the ASRock N3700-ITX (2 ports):
Note: Each drive is on one port of each dual port controller.
hdparm -tT /dev/disk/by-id/ata-ST3000VN000-1HJ166_W6A0J98V
/dev/disk/by-id/ata-ST3000VN000-1HJ166_W6A0J98V:
Timing cached reads: 2816 MB in 2.00 seconds = 1408.44 MB/sec
Timing buffered disk reads: 482 MB in 3.00 seconds = 160.60 MB/sec
Timing cached reads: 2668 MB in 2.00 seconds = 1333.80 MB/sec
Timing buffered disk reads: 484 MB in 3.01 seconds = 160.96 MB/sec
And the same model drive on the other controller:
hdparm -tT /dev/disk/by-id/ata-ST3000VN000-1HJ166_W7305P38
Timing cached reads: 2720 MB in 2.00 seconds = 1360.45 MB/sec
Timing buffered disk reads: 534 MB in 3.00 seconds = 177.76 MB/sec
/dev/disk/by-id/ata-ST3000VN000-1HJ166_W7305P38:
Timing cached reads: 2764 MB in 2.00 seconds = 1382.44 MB/sec
Timing buffered disk reads: 544 MB in 3.01 seconds = 181.01 MB/sec
However these 2 drives have also tested differently on the same controller so there can be a difference from drive to drive anyway.
See what your get on your hardware with the same tests to try and narrow down what’s going on.
