Installation issues
Hey guys!
A while ago I saw someone on here used an AM1 setup and decided to get another box with this hardware (my HTPC runs off this). Using a 5350 and a https://www.asus.com/ca-en/Motherboards/AM1MA/specifications/ with 8GB of 2133 (running at 1600)
I am currently testing with two dying 160GB drives, but bought 2X3TB (need to pick them up).
I’ve tried using Rufus/Rawrite/LiveCD creator and all of these options are throwing issues when I try to install the OS to a 8 GB USB2.0 drive from a 4GB one.
I’ve now experienced yumpackage and other .py errors the moment I try to actually install Rockstor onto the 8GB USB.
I’ve disabled all the fast boot/UEFI boot, changes everything to OTHER OS and legacy in bios.
Any thoughts? Should I find a DVD drive and go this route? Is there something I am missing?
Any help would be amazing!
i made one fine the other day using dd. just be absolutely sure you are choosing your usb stick when pointing to your /dev/sdX device. pick the wrong one and kiss any data on that disk buhbye.
ie
 dd if=/path/to/my/iso.iso of=/dev/sdX bs=4M
here is a link about it too.
https://wiki.archlinux.org/index.php/USB_flash_installation_media
When using rufus to create the install USB: Did you use writing in ISO oder in DD mode?
I found that write in ISO mode leads into problems. So use DD mode.
Have you read our quickstart guide?
