Hi everyone and @khanh (I hook you up from(System Drive Performance Boost: M.2 Drive vs USB 3.0 - #2 by khanh))
So I tried several time to install Rockstor on 2 perfectly identical Kingston DataTraveler SE9 G2 (16GB, USB 3.0) which run without issue CentOS7 (RAID1 on XFS) and FreeNAS (ZFS Mirror), so I believe it’s not the USB stick the issue.
I also try to install on only one USB Stick with same issue
The issue is; after a very long installation (almost an hour) I never able to reboot and Rockstor (CentOS) complain about some missing mountpoint.
Now just to mention this is also happen if I use the unattended installation (which use the Rockstor partition scheme).
I would like some output from users use Rockstor on usb
- if they made partition
- if they try RAID
Thank you
