Sorry it took me a while to get back to my Rockstor project. In the past week I got another mother board that was known to work on Rockstor and tried to set it up as a Rockstor system. The exact same problem occurred with the new mother board. Given that this was a known good board, I turned my attention from the machine to the network. I tried to install the latest stable release on the new board after connecting it to an old Netgear 10/100 switch that was in turn connected to my Dell switch that is the heart of my network. The installation went flawlessly. I tried the TB250-BTCPRO board going through the old Netgear switch and it went flawlessly as well. I have never had any problems in the past with the Dell switch. It has some fancy features like POE, Qos, and virtual networks but none of that has ever gotten in my way before and I don’t think it has now. It has been totally comparable with everything I’ve hooked up to it until Rockstor. It has worked with PCs running centos, ubuntu, the latest OpenSuse, winXP, win7, and win10. It has also played nicely with the TB250-BTCPRO board with win10 and OpenSuse. It has never had an issue with various IP devices such as WiFi access points, IP cameras, and IP Phones. It just does not like Rockstor.
My take away from this is that Rockstor OS/Driver is working with the NIC hardware properly and the problem is that the Rockstor OS/Driver is not working with the protocols that the Dell switch wants to use.
Now that I can access the logs, I can send any logs that anyone may want to see. In the mean time I am looking into updating the firmware in the Dell switch.
Is there anything else that I should look at? I did look at the lspci -v command in the actual Rockstor installation. I’m not sure if it showed any problems or not. I’m guessing that at this point with the system working through the old switch it will not show any errors in the PCI bus but if you want to see the output I will try to figure out how to retrieve it from the main console.
Looking forward to hearing anyone’s ideas on what to do next. Maybe a setting in the switch or in the BIOS of these boards. Thanks for all your help so far.
