I tried setting up Team on my Rockstor machine and received this error.
Houston, we’ve had a problem.
Error running a command. cmd = /usr/bin/nmcli c up Team0-slave-0. rc = 4. stdout = [‘’]. stderr = [‘Error: Connection activation failed: A dependency of the connection failed’, “Hint: use ‘journalctl -xe NM_CONNECTION=e55eed4f-e975-4b38-905a-04ec276a654d + NM_DEVICE=eth1’ to get more details.”, ‘’]
File "/opt/rockstor/src/rockstor/rest_framework_custom/generic_view.py", line 41, in _
handle_exception
File "/opt/rockstor/src/rockstor/storageadmin/views/network.py", line 342, in post
search_domains,
File "/opt/rockstor/src/rockstor/system/network.py", line 401, in new_team_connection
new_member_helper(name, members, "team-slave")
File "/opt/rockstor/src/rockstor/system/network.py", line 369, in new_member_helper
run_command([NMCLI, "c", "up", mname])
File "/opt/rockstor/src/rockstor/system/osi.py", line 201, in run_command
CommandException: Error running a command. cmd = /usr/bin/nmcli c up Team0-slave-0. rc = 4. stdout = ['']. stderr = ['Error: Connection activation failed: A dependency of the connection failed', "Hint: use 'journalctl -xe NM_CONNECTION=e55eed4f-e975-4b38-905a-04ec276a654d + NM_DEVICE=eth1' to get more details.", '']
Also I’ve got the output from
“journalctl -xe NM_CONNECTION=e55eed4f-e975-4b38-905a-04ec276a654d + NM_DEVICE=eth1”
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6539] dhcp4 (eth1): option requested_host_name => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6539] dhcp4 (eth1): option requested_interface_mtu => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6539] dhcp4 (eth1): option requested_ms_classless_static_routes => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6539] dhcp4 (eth1): option requested_nds_context => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6539] dhcp4 (eth1): option requested_nds_servers => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6539] dhcp4 (eth1): option requested_nds_tree_name => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_netbios_dd_server => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_netbios_name_servers => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_netbios_node_type => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_netbios_scope => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_nis_domain => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_nis_servers => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_ntp_servers => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_rfc3442_classless_static_routes => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_root_path => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_routers => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_static_routes => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_subnet_mask => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option requested_wpad => '1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option routers => '192.168.1.1'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option server_name => 'ecosystem.home.cisco.com'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): option subnet_mask => '255.255.255.0'
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6540] dhcp4 (eth1): state changed unknown -> extended
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6546] device (eth1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6555] device (eth1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.6557] device (eth1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jul 20 19:32:37 Tesseract NetworkManager[762]: <info> [1626827557.7636] device (eth1): Activation: successful, device activated.
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.6243] device (eth1): disconnecting for new activation request.
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.6243] device (eth1): state change: activated -> deactivating (reason 'new-activation', sys-iface-state: 'managed>Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.6665] device (eth1): state change: deactivating -> disconnected (reason 'new-activation', sys-iface-state: 'mana>Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.6832] dhcp4 (eth1): canceled DHCP transaction, DHCP client pid 1253
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.6833] dhcp4 (eth1): state changed extended -> done
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8546] device (eth1): Activation: starting connection 'Team0-slave-0' (3a6f465e-31af-46db-b64c-cf48fbe78a57)
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8553] device (eth1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8555] device (eth1): state change: prepare -> failed (reason 'dependency-failed', sys-iface-state: 'managed')
Jul 20 19:46:11 Tesseract NetworkManager[762]: <warn> [1626828371.8559] device (eth1): Activation: failed for connection 'Team0-slave-0'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8560] device (eth1): state change: failed -> disconnected (reason 'none', sys-iface-state: 'managed')
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8570] device (eth1): Activation: starting connection 'Connection1' (8d9ff00d-caf1-4df7-8d85-091d80e3ea20)
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8571] device (eth1): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8573] device (eth1): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8576] device (eth1): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8578] dhcp4 (eth1): activation: beginning transaction (timeout in 45 seconds)
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8590] dhcp4 (eth1): dhclient started with pid 19806
Jul 20 19:46:11 Tesseract NetworkManager[762]: <error> [1626828371.8601] device (eth1): addrconf6: failed to start neighbor discovery: failure creating libndp socket: Address fami>Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8934] dhcp4 (eth1): address 192.168.1.195
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8935] dhcp4 (eth1): plen 24 (255.255.255.0)
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8935] dhcp4 (eth1): gateway 192.168.1.1
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8935] dhcp4 (eth1): lease time 86400
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8935] dhcp4 (eth1): hostname 'TESSERACT'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8935] dhcp4 (eth1): nameserver '192.168.1.1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8935] dhcp4 (eth1): domain name 'gvtc.com'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8935] dhcp4 (eth1): option broadcast_address => '192.168.1.255'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8935] dhcp4 (eth1): option dad_wait_time => '0'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8935] dhcp4 (eth1): option dhcp_lease_time => '86400'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option dhcp_message_type => '5'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option dhcp_rebinding_time => '75600'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option dhcp_renewal_time => '43200'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option dhcp_server_identifier => '192.168.1.1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option domain_name => 'gvtc.com'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option domain_name_servers => '192.168.1.1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option expiry => '1626914771'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option host_name => 'TESSERACT'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option ip_address => '192.168.1.195'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option network_number => '192.168.1.0'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option next_server => '192.168.1.1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_broadcast_address => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_domain_name => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_domain_name_servers => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_domain_search => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_host_name => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_interface_mtu => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_ms_classless_static_routes => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_nds_context => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_nds_servers => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_nds_tree_name => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_netbios_dd_server => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8936] dhcp4 (eth1): option requested_netbios_name_servers => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_netbios_node_type => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_netbios_scope => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_nis_domain => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_nis_servers => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_ntp_servers => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_rfc3442_classless_static_routes => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_root_path => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_routers => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_static_routes => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_subnet_mask => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option requested_wpad => '1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option routers => '192.168.1.1'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option server_name => 'ecosystem.home.cisco.com'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): option subnet_mask => '255.255.255.0'
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8937] dhcp4 (eth1): state changed unknown -> extended
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8945] device (eth1): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8961] device (eth1): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Jul 20 19:46:11 Tesseract NetworkManager[762]: <info> [1626828371.8962] device (eth1): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Jul 20 19:46:12 Tesseract NetworkManager[762]: <info> [1626828372.0067] device (eth1): Activation: successful, device activated.
lines 38-133/133 (END)
