I would advise to search the internets for “prepare_namespace” and “mount_block_root” but those 2 spots seems to be pretty bad …
I hope that this is not a main FS that it’s craping out on.
pointless to say: “backups ?”
I’m not sure I’ve made this clear before but alto N40L is a cheap and cheerful system to run (power consumption wise) that is a complete crap generating errors and sending people data to data heaven You may not know it but fact you’re not using ECC ram means you are asking for it … I’m not jumping down on you … it’s simply impossible to expect anybody trying to be serious about data storage to know this somehow contradicting fact - but ECC ram is a must in storage systems … 95% of problem are eliminated by having ECC …
As an explanation here - all modern “advanced” filesystems keep a large hierarchy / structures / trees in RAM to accelerate operations and keep data syncing optimal (zfs, btrfs, xfs) … down side is that is you get an error in ram … it may confuse algorithms operating on this data and next time it will sync to hard storage you might as well end up with large array or random 0 and 1
