I’m trying to install RockStor in a KVM on ProxmoxVE using Virtio storage & the installer fails because it doesn’t see a disk called sda- they’re vd(a,b,c).
So I created an additional 1G SATA disk to satisfy the installer’s limitation & got through the installer. Then I tried booting after removing the 1G SATA sda disk, & it drops me into an emergency shell- won’t start. Even if I leave the 1G SATA sda there unmounted, I still end up with the emergency shell at boot.
Is there a file in the iso I can maybe edit & remove this dependency on sda?
Install your RockStor installation on a SATA disk. After installation, power down the RockStor install and change it into a Virtio based disk. This will require creating a new Virtio disk, then copying over the SATA based disk on top of it.
