Lychee-Docker Rockon
I’d like to add a new Rockon to the repository for photo management. Does anyone here have a little free time to create a proper How-To document that we can pin on these forums? A nice, step-by-step outline with example snippets of working/existing Rockons would be a great starting place.
Lychee
https://hub.docker.com/r/kdelfour/lychee-docker/
Edit:
I think I found what I was looking for.
@wwwizzarrdry, would you consider using the official docker image instead?
https://hub.docker.com/r/lycheeorg/lychee
Mostly, because the other image was updated 6 years ago for the last time and is only available for the amd64 architecture. We want to try to provide Rockons that can be run both under amd64 and arm64.
