Hi All,
I decided to upgrade from 3.9 to 4.0, I reinstalled and everything was going great, I went into the web ui and set a static IP address which is where my issues started.
The IP Address wasnt updating as expected, I rebooted and then lost connection, turns out it had updated the IP Address but rockstor was still telling me to connect on the DHCP address.
I then decided to assign the IP Address with a static lease through my router (OPNSense) and then re-install rockstor, my device picks up the IP Address during install and works without issue, then it goes offline…
I have no idea why its going offline, my switch shows it connected, ip a shows it connected and running nmcli also shows it connected. However my router shows it as offline which doesnt make sense.
Ive tried everything that I can think of but it doesnt want to work again… any ideas what could be causing this?
I wouldnt mind but the first time I installed it worked perfectly until I tried to set the static IP Address.
Any help would be appreciated
Personally I think that you should have the option at install to set the IP Address or use DHCP…
