@RlndVt hello again.
Fundamentally, nothing speaks against having the AiO package also published as a Rockon. We would probably start out with both of them available, and then (if/when it makes sense) deprecate the “simple” one.
Do you fancy opening an issue on the Rockon repository? Also, if you feel comfortable you can take a shot a proposing a Rockon json setup. In absence of that, if you have tested it already, can you post which parameter you considered relevant/not useful for it to work?
As usual, we want to get to a “mainstream” setup that can hopefully be used by the majority of users.
