Not all AD groups are shown in Rockstor
Rockstor 3.9.2-57
AD is 2012 R2 (yes, I know it’s old)
This is not a new installation and it’s mostly works fine.
However, we have one AD security group that does not show up in Rockstor Groups, therefore I can’t use it for share permissions.
The Rockstor network connection is pointing to the windows DNS servers in my AD. AD replication works fine.
When I ssh to the Rockstor command line, wbinfo -g shows the group names but there’s one in particular that is shown in this list that is NOT shown on the Rockstor webpage so I can’t assign it to Samba share permissions.
Does anyone have any idea why this is happening and what I can do to fix it?
Thanks!
@MRC-MBU Hello again.
Possibly. How may users do you have in your AD domain.
We recently again ran into a self imposed user limit and increased it. Hence the question. The last increase was in version 4.0.2 in the following:
https://github.com/rockstor/rockstor-core/issues/2211
with that issue referencing the previous ‘expansion’ from 5000 in:
https://github.com/rockstor/rockstor-core/issues/1915
which was in turn released in version 3.9.2-22 so you should already have this > 5000 expansion ‘fix’ in place:
Note that the last release of the v3 variant (CentOS based) was the one you are currently running: 3.9.2-57. But note that, as requested in your earlier post here:
and my response there. The output of the following command:
yum info rockstor
Is important to check as we did have a fault way back where the Web-UI would incorrectly report the latest available as installed !!
Hello, Philip,
yum info rockstor gives:
  • base: centos.mirrors.nublue.co.uk
  • epel: epel.besthosting.ua
  • extras: mirror.as29550.net
  • updates: anorien.csc.warwick.ac.uk
    Installed Packages
    Arch : x86_64
    Version : 3.9.2
    Release : 57
    Repo : installed
    From repo : Rockstor-Stable
    Summary : Btrfs Network Attached Storage (NAS) Appliance.
    URL : http://rockstor.com/
    License : GPL
    Description : Software raid, snapshot capable NAS solution with built-in file
    : integrity protection. Allows for file sharing between network
    : attached devices.
Our AD users are hundreds but well under a thousand so that shouldn’t be an issue.
Anything else to look at?
Many thanks,
Eric
