I have Rockstor booting off a fairly small (16 GB) SSD boot drive, which I’ve found will fill up if I don’t manually run a balance operation every couple or few weeks.
I could simply create a cronjob to take care of this, but can’t we do better?
Sure we can! What would you like to do?
TBH, I’m not 100% sure. One option would be to allow scheduled tasks for balancing.
Just bumping this.
The other issue is I thought more recent BTRFS releases do auto-rebalancing, but @suman mentioned some problem with upgrading earlier installs.
I ended up setting up a cron job to balance weekly. FWIW, this is what I see two days after a balance. This is not an intensively used system; should I be rebalancing daily?
# btrfs fi usage /
Overall:
Device size: 12.93GiB
Device allocated: 7.53GiB
Device unallocated: 5.40GiB
Device missing: 0.00B
Used: 6.18GiB
Free (estimated): 6.42GiB (min: 6.42GiB)
Data ratio: 1.00
Metadata ratio: 1.00
Global reserve: 80.00MiB (used: 0.00B)
