ownCloud docker how to forward specific IP:443 to owncloud port 443
Hi all,
Currently any connection to port 8080 is being forwarded to port 443 on the owncloud instance.
DOCKERINSTANCEID pschmitt/owncloud “/usr/bin/run.sh” 27 hours ago Up 4 seconds 80/tcp, 0.0.0.0:8080->443/tcp owncloud
But I want to create an Alias IP and forward that on port 443 like this:
DOCKERINSTANCEID pschmitt/owncloud “/usr/bin/run.sh” 27 hours ago Up 4 seconds 80/tcp, 10.0.5.108:443->443/tcp owncloud
How do I set that up? :blush:
8080 is the default value auto filled in the install wizard during the Rock-on installation. You can provide other port number instead of 8080. 443 will cause problems because Rockstor web-ui run on that port. There is a pending issue to support custom port but it’s not supported yet.
This is off the top of my head and i’m not prepared to enable Rock-Ons to test the forwarding part
On the rockstor machine
ifconfig eth0:1 (ip)/cidr
e.g if your main IP was 192.168.1.10 and you wanted 192.168.1.14 it would be
ifconfig eth0:1 192.168.1.14/24
Then change the 0.0.0.0:8080 > 443/tcp owncloud to (ip):443 > 443/tcp owncloud
so in my above example it would 192.168.1.14:443 > 443/tcp owncloud
If that works then we’ll need to either script the addation of the IP address or change the networking config to make the ifalias permanent
@Dragon2611
Thanks for the comment.
I finally decided to setup owncloud on a dedicated virtual machine and mount the data share from the rockstor NAS via NFS. I think this is a more flexible approach.
Regards, Koen
Did you have “fun” with permissions when doing that?
No issues with permissions so far, but havent tested it completely.
I just created the apache user with same uid/gid on the rockstor server and changed owncloud share permission and ownership .
Ah I just mounted with no root squash (possibly not the best approach from a secuirty viewpoint)
Edit: That reminds me @suman mind taking a look at issue #991 it’s tripped me up a couple times if I forget about it.
