I recently set up an install of Rockstor and moved over four varying size hard drives into a pool, adding one at a time. When I added the last one, I received an error in the Balances tab:
Error running a command. cmd = ['btrfs', 'balance', 'start', '-mconvert=single', '-dconvert=single', '/mnt2/media']. rc = 1. stdout = ['']. stderr = ["ERROR: error during balancing '/mnt2/media': Input/output error", 'There may be more info in syslog - try dmesg | tail', '']
Running a manual balance yielded another error:
Error running a command. cmd = ['btrfs', 'balance', 'start', '/mnt2/media']. rc = 1. stdout = ['WARNING:', '', '\tFull balance without filters requested. This operation is very', '\tintense and takes potentially very long. It is recommended to', '\tuse the balance filters to narrow down the balanced data.', "\tUse 'btrfs balance start --full-balance' option to skip this", '\twarning. The operation will start in 10 seconds.', '\tUse Ctrl-C to stop it.', '10 9 8 7 6 5 4 3 2 1', 'Starting balance without any filters.', '']. stderr = ["ERROR: error during balancing '/mnt2/media': Input/output error", 'There may be more info in syslog - try dmesg | tail', '']
Running btrfs fi show I can see the last HDD added is not balanced:
Label: 'media' uuid: 39fc85f1-e863-41a7-9bc9-3452c9bd9e4d
Total devices 4 FS bytes used 2.42TiB
devid 1 size 596.17GiB used 294.01GiB path /dev/sda
devid 2 size 1.82TiB used 1.52TiB path /dev/sdg
devid 3 size 931.51GiB used 629.00GiB path /dev/sdf
devid 4 size 2.73TiB used 2.00GiB path /dev/sdh
In the Rockstor Logs I see the following errors:
[12/Oct/2016 09:04:58] ERROR [smart_manager.data_collector:620] Failed to update disk state.. exception: 500 Server Error: INTERNAL SERVER ERROR
[12/Oct/2016 09:06:14] ERROR [storageadmin.views.command:75] Exception while refreshing state for Pool(rockstor_rockstor). Moving on: deadlock detected
DETAIL: Process 7634 waits for ShareLock on transaction 24086; blocked by process 7689.
Process 7689 waits for ShareLock on transaction 24088; blocked by process 7634.
HINT: See server log for query details.
[12/Oct/2016 09:06:14] ERROR [storageadmin.views.command:76] deadlock detected
File "/opt/rockstor/src/rockstor/storageadmin/views/command.py", line 71, in _refresh_pool_state
p.save()
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/base.py", line 545, in save
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/base.py", line 573, in save_base
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/base.py", line 635, in _save_table
forced_update)
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/base.py", line 679, in _do_update
return filtered._update(values) > 0
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/query.py", line 510, in _update
return query.get_compiler(self.db).execute_sql(None)
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/sql/compiler.py", line 980, in execute_sql
cursor = super(SQLUpdateCompiler, self).execute_sql(result_type)
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/sql/compiler.py", line 786, in execute_sql
cursor.execute(sql, params)
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/util.py", line 53, in execute
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/utils.py", line 99, in __exit__
OperationalError: deadlock detected
[12/Oct/2016 09:08:44] ERROR [storageadmin.views.command:75] Exception while refreshing state for Pool(rockstor_rockstor). Moving on: deadlock detected
DETAIL: Process 8122 waits for ShareLock on transaction 24150; blocked by process 8168.
Process 8168 waits for ShareLock on transaction 24139; blocked by process 8122.
[12/Oct/2016 09:08:44] ERROR [storageadmin.views.command:76] deadlock detected
p.save()
forced_update)
[12/Oct/2016 09:09:58] ERROR [storageadmin.views.command:75] Exception while refreshing state for Pool(rockstor_rockstor). Moving on: deadlock detected
DETAIL: Process 8341 waits for ShareLock on transaction 24173; blocked by process 8343.
Process 8343 waits for ShareLock on transaction 24175; blocked by process 8341.
[12/Oct/2016 09:09:58] ERROR [storageadmin.views.command:76] deadlock detected
p.save()
forced_update)
[12/Oct/2016 09:10:51] ERROR [storageadmin.views.command:75] Exception while refreshing state for Pool(files). Moving on: deadlock detected
DETAIL: Process 8518 waits for ShareLock on transaction 24205; blocked by process 8603.
Process 8603 waits for ShareLock on transaction 24200; blocked by process 8518.
[12/Oct/2016 09:10:51] ERROR [storageadmin.views.command:76] deadlock detected
p.save()
forced_update)
[12/Oct/2016 09:10:51] ERROR [storageadmin.middleware:35] Exception occured while processing a request. Path: /api/commands/refresh-pool-state method: POST
[12/Oct/2016 09:10:51] ERROR [storageadmin.middleware:36] An error occurred in the current transaction. You can't execute queries until the end of the 'atomic' block.
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/core/handlers/base.py", line 112, in get_response
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/views/decorators/csrf.py", line 57, in wrapped_view
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/views/generic/base.py", line 69, in view
return func(*args, **kwargs)
File "/opt/rockstor/src/rockstor/storageadmin/views/command.py", line 253, in post
self._refresh_pool_state()
File "/opt/rockstor/src/rockstor/storageadmin/views/command.py", line 61, in _refresh_pool_state
if (p.disk_set.count() == 0):
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/manager.py", line 136, in count
return self.get_queryset().count()
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/query.py", line 294, in count
return self.query.get_count(using=self.db)
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/sql/query.py", line 390, in get_count
number = obj.get_aggregation(using=using)[None]
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/models/sql/query.py", line 356, in get_aggregation
result = query.get_compiler(using).execute_sql(SINGLE)
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/util.py", line 47, in execute
self.db.validate_no_broken_transaction()
File "/opt/rockstor/eggs/Django-1.6.11-py2.7.egg/django/db/backends/__init__.py", line 372, in validate_no_broken_transaction
"An error occurred in the current transaction. You can't "
TransactionManagementError: An error occurred in the current transaction. You can't execute queries until the end of the 'atomic' block.
[12/Oct/2016 09:10:51] ERROR [smart_manager.data_collector:620] Failed to update pool state.. exception: ['Internal Server Error: No JSON object could be decoded']
Any help is greatly appreciated!
