I try to setup a fresh Rockstor server. It runs under ESXi hypervisor with a passed thru SATA controller.
I always run into the problem, that my pools and shares are unmounted after some reboots.
I install from the 3.9.1 ISO. After this I activate my subscription and update to 3.9.2-53.
Then reboot. Mostly then the pools are mounted.
The I am going to configure my system. At some point I do a reboot and after the pools are unmounted.
See screenshot attached.
I found that the bootstrap service is not started and I am unable to start it manually.
Here is the log:
Feb 19 22:26:13 storage bootstrap[4263]: BTRFS device scan complete
Feb 19 22:26:13 storage bootstrap[4263]: Exception occured while bootstrapping. This could be because rockstor.service is still starting up. will wait 2 seconds and try again. Exception: OauthApp matching query does not exist.
Feb 19 22:26:13 storage bootstrap[4263]: Max attempts(15) reached. Connection errors persist. Failed to bootstrap. Error: OauthApp matching query does not exist.
Feb 19 22:26:13 storage systemd[1]: rockstor-bootstrap.service: main process exited, code=exited, status=1/FAILURE
Feb 19 22:26:13 storage systemd[1]: Failed to start Rockstor bootstrapping tasks.
Feb 19 22:26:13 storage systemd[1]: Unit rockstor-bootstrap.service entered failed state.
Feb 19 22:26:13 storage systemd[1]: rockstor-bootstrap.service failed.
Any idea what to do?
I tried several installs. No luck.
