Problem installing from SD card
Hi!
I’ve been trying to install Rockstor from an SD card for some time today. Unfortunately my last USB drive broke, and I need to set up my server before 4th Jan. Due to new years’ eve, no store will be open till 4th, and I simply can’t get any further.
It boots fine from the SD card, however as soon as I’d start the install process, it dies with a console message saying that it couldn’t find all disks. From there, I can’t progress at all, my only option is to reboot (it presents an emergency console).
Has anyone ran into this issue before?
Not an answer, I’m afraid. Just to confirm - I loaded the .iso to a 2 GB flash drive (using dd) and had exactly the same problem. I could boot, but any attempt to install failed. It also failed when trying to verify the media.
Paul.
