Hi, all, I’m new to Rockstor and built my own NAS (below).
The install seems to have gone fine, but now I am having a problem with making a RAID 0 array with 2 Ironwolf 8TB HDD (I’ll change to 10 when I get 2 more drives).
I created the new pool as raid 0 and it said 14.x TB total space. Then I went to create a share on it for media and it says only 7.x TB of space are available, and Y of Infinity% space is used.
Is this just a bad drive that I need to RMA, or is there something I need to do in software/hardware to fix it?
@Samuryno Welcome to the Rockstor community forum.
We may just have a size calculation bug for this raid level:
We tent to focus on the redundant btrfs-raid profiles at that is mostly what folks tend to use.
Yes, 7 TB is more akin to a btrfs-raid1 with these 2 drives.
Looks very odd. Could you let us know if you have quotas disabled (the are enabled by default) that will remove some size info availability on the share side of things.
Also if you post the output of the following commands, run as root, it should help folks here on the forum know more about what may be happening:
for overall system btrfs layout
btrfs fi show
for the specific data pool info regarding raid levels etc:
btrfs fi usage /mnt2/your-data-pool-name-here
Plus a screen grab of the Pool details page so we can see the differences as it were.
We also need to know the Rockstor version and update channel (if any) you are using.
