Yesterday I had a Error to write Data to my Filesystem. After reboot the Share “Allgemein” on a Raid 5 isn’t avaible.
I could’t boot from the actual Version Linux-4.8.7, I have to fall back to 4.6.0.
I need help, e2fsck/ fsck.ext4 dosn’t help
can I mount in Commandline this Share once, it could help to save my files.
some Error in the dmesg
CommandException: Error running a command. cmd = [’/bin/mount’, ‘/dev/disk/by-label/Allgemein’, ‘/mnt2/Allgemein’, ‘-o’, ‘,compress=lzo’]. rc = 32. stdout = [’’]. stderr = [‘mount: wrong fs type, bad option, bad superblock on /dev/sde,’, ’ missing codepage or helper program, or other error’, ‘’, ’ In some cases useful info is found in syslog - try’, ’ dmesg | tail or so.’, ‘’]
[04/Apr/2017 08:22:16] ERROR [storageadmin.views.command:75] Exception while refreshing state for Pool(Allgemein). Moving on: Error running a command. cmd = [’/bin/mount’, ‘/dev/disk/by-label/Allgemein’, ‘/mnt2/Allgemein’, ‘-o’, ‘,compress=lzo’]. rc = 32. stdout = [’’]. stderr = [‘mount: wrong fs type, bad option, bad superblock on /dev/sde,’, ’ missing codepage or helper program, or other error’, ‘’, ’ In some cases useful info is found in syslog - try’, ’ dmesg | tail or so.’, ‘’]
[root@de-nb0-sv-103 dev]# btrfs fi show
Label: ‘rockstor_de-nb0-sv-103’ uuid: 18b923a3-77a5-4690-a096-103095af6674
Total devices 1 FS bytes used 2.07GiB
devid 1 size 61.04GiB used 5.04GiB path /dev/sda3
Label: ‘Backup’ uuid: 9cf93739-e206-4051-9f21-a39d2c637598
Total devices 1 FS bytes used 26.03GiB
devid 1 size 68.37GiB used 27.05GiB path /dev/sdb
Label: ‘Allgemein’ uuid: 2471ad59-ad98-4379-947a-337d039096f0
Total devices 4 FS bytes used 336.74GiB
devid 1 size 279.40GiB used 139.00GiB path /dev/sdd
devid 2 size 279.40GiB used 139.00GiB path /dev/sde
devid 3 size 279.40GiB used 139.00GiB path /dev/sdf
devid 4 size 279.40GiB used 139.00GiB path /dev/sdc
best regards Rine
