Prior to jumping on the 5.0.14 version I was on stable and would do a daily balance on my media pool (raid5-1). Ever since the update to 5.0.14 (fresh install, pools imported) this balance has failed nearly immediately with nothing showing up in the dmesg logs other than “balance: ended with status: -5”. I’ve tried this with the previously scripted balance and the balance command from the web-ui and both fail. All the data appears to be there and the configs for my docker containers on this pool all appear without issue.
Dmesg output:
rockstor1:~ # dmesg | grep "BTRFS"
[ 8.424742] BTRFS: device label ROOT devid 1 transid 69930 /dev/sdi4 scanned by (udev-worker) (430)
[ 8.559169] BTRFS: device label Media devid 5 transid 4294346 /dev/sda scanned by (udev-worker) (422)
[ 8.564140] BTRFS: device label Media devid 6 transid 4294346 /dev/sdb scanned by (udev-worker) (432)
[ 8.577875] BTRFS: device label Media devid 7 transid 4294346 /dev/sdd scanned by (udev-worker) (412)
[ 8.583802] BTRFS: device label Scratch devid 1 transid 7194986 /dev/sdf scanned by (udev-worker) (440)
[ 8.587710] BTRFS: device label Media devid 4 transid 4294346 /dev/sdh scanned by (udev-worker) (426)
[ 8.601289] BTRFS: device label Scratch devid 2 transid 7194986 /dev/sde scanned by (udev-worker) (446)
[ 8.656960] BTRFS: device label Media devid 3 transid 4294346 /dev/sdc scanned by (udev-worker) (408)
[ 9.228776] BTRFS: device label rockon_root devid 1 transid 57030 /dev/sdk scanned by (udev-worker) (429)
[ 9.303109] BTRFS info (device sdi4): using crc32c (crc32c-intel) checksum algorithm
[ 9.303191] BTRFS info (device sdi4): disk space caching is enabled
[ 9.311898] BTRFS info (device sdi4): enabling ssd optimizations
[ 9.311957] BTRFS info (device sdi4): auto enabling async discard
[ 71.428145] BTRFS info (device sdk): using crc32c (crc32c-intel) checksum algorithm
[ 71.428241] BTRFS info (device sdk): use no compression
[ 71.428303] BTRFS info (device sdk): using free space tree
[ 71.460014] BTRFS info (device sdk): enabling ssd optimizations
[ 71.460083] BTRFS info (device sdk): auto enabling async discard
[ 71.499551] BTRFS info (device sdf): using crc32c (crc32c-intel) checksum algorithm
[ 71.499631] BTRFS info (device sdf): use no compression
[ 71.499686] BTRFS info (device sdf): disk space caching is enabled
[ 80.439927] BTRFS info (device sdc): using crc32c (crc32c-intel) checksum algorithm
[ 80.440010] BTRFS info (device sdc): use no compression
[ 80.440065] BTRFS info (device sdc): disk space caching is enabled
[ 381.150452] BTRFS info (device sdc): balance: start -dusage=85,limit=10 -musage=85,limit=10 -susage=85,limit=10
[ 381.152000] BTRFS info (device sdc): relocating block group 45761820557312 flags data|raid5
[ 392.063408] BTRFS info (device sdc): found 18 extents, stage: move data extents
[ 392.742247] BTRFS info (device sdc): found 18 extents, stage: update data pointers
[ 393.190904] BTRFS info (device sdc): relocating block group 43267484745728 flags data|raid5
[ 411.871904] BTRFS info (device sdc): balance: ended with status: -5
[ 562.973437] BTRFS info (device sdc): balance: start -d -m -s
[ 562.974682] BTRFS info (device sdc): relocating block group 45767189266432 flags data|raid5
[ 573.400294] BTRFS info (device sdc): found 18 extents, stage: move data extents
[ 573.811803] BTRFS info (device sdc): found 18 extents, stage: update data pointers
[ 574.195688] BTRFS info (device sdc): relocating block group 45766115524608 flags metadata|raid1
[ 584.170300] BTRFS info (device sdc): found 11066 extents, stage: move data extents
[ 585.039617] BTRFS info (device sdc): relocating block group 45757525590016 flags data|raid5
[ 608.600024] BTRFS info (device sdc): found 34 extents, stage: move data extents
[ 608.902413] BTRFS info (device sdc): found 34 extents, stage: update data pointers
[ 609.243256] BTRFS info (device sdc): relocating block group 45753230622720 flags data|raid5
[ 631.624949] BTRFS info (device sdc): found 35 extents, stage: move data extents
[ 631.994548] BTRFS info (device sdc): found 35 extents, stage: update data pointers
[ 632.382191] BTRFS info (device sdc): relocating block group 45748935655424 flags data|raid5
[ 654.662641] BTRFS info (device sdc): found 34 extents, stage: move data extents
[ 655.093814] BTRFS info (device sdc): found 34 extents, stage: update data pointers
[ 655.371374] BTRFS info (device sdc): relocating block group 45744640688128 flags data|raid5
[ 679.541004] BTRFS info (device sdc): found 36 extents, stage: move data extents
[ 679.961845] BTRFS info (device sdc): found 36 extents, stage: update data pointers
[ 680.507792] BTRFS info (device sdc): relocating block group 45740345720832 flags data|raid5
[ 704.115503] BTRFS info (device sdc): found 33 extents, stage: move data extents
[ 704.475737] BTRFS info (device sdc): found 33 extents, stage: update data pointers
[ 704.823672] BTRFS info (device sdc): relocating block group 45736050753536 flags data|raid5
[ 726.714378] BTRFS info (device sdc): found 35 extents, stage: move data extents
[ 727.030713] BTRFS info (device sdc): found 35 extents, stage: update data pointers
[ 727.348683] BTRFS info (device sdc): relocating block group 45731755786240 flags data|raid5
[ 750.702239] BTRFS info (device sdc): found 33 extents, stage: move data extents
[ 751.082542] BTRFS info (device sdc): found 33 extents, stage: update data pointers
[ 751.431438] BTRFS info (device sdc): relocating block group 45727460818944 flags data|raid5
[ 772.952816] BTRFS info (device sdc): found 34 extents, stage: move data extents
[ 773.267128] BTRFS info (device sdc): found 34 extents, stage: update data pointers
[ 773.587739] BTRFS info (device sdc): relocating block group 45723165851648 flags data|raid5
[ 797.411807] BTRFS info (device sdc): found 35 extents, stage: move data extents
[ 797.762061] BTRFS info (device sdc): found 35 extents, stage: update data pointers
[ 798.121735] BTRFS info (device sdc): relocating block group 45636192763904 flags data|raid5
[ 823.464527] BTRFS info (device sdc): balance: ended with status: -5
BTRFS Fi:
rockstor1:~ # btrfs fi show
Label: 'ROOT' uuid: 46befa9e-b399-480d-b10d-338a4c875615
Total devices 1 FS bytes used 8.23GiB
devid 1 size 230.82GiB used 10.05GiB path /dev/sdi4
Label: 'rockon_root' uuid: 3214523d-00c7-4503-94cd-e4a28380ba2b
Total devices 1 FS bytes used 27.77GiB
devid 1 size 238.47GiB used 32.02GiB path /dev/sdk
Label: 'Scratch' uuid: 0eec16fe-5dd6-46d8-b325-0778e9b4598a
Total devices 2 FS bytes used 1.13TiB
devid 1 size 1.82TiB used 1.14TiB path /dev/sdf
devid 2 size 1.82TiB used 1.14TiB path /dev/sde
Label: 'Media' uuid: 525f9c00-5f14-43ad-abdb-65f1ef24a9f9
Total devices 5 FS bytes used 7.18TiB
devid 3 size 3.64TiB used 1.93TiB path /dev/sdc
devid 4 size 3.64TiB used 1.93TiB path /dev/sdh
devid 5 size 3.64TiB used 1.93TiB path /dev/sda
devid 6 size 3.64TiB used 1.93TiB path /dev/sdb
devid 7 size 3.64TiB used 1.93TiB path /dev/sdd
Media pool usage:
rockstor1:~ # btrfs fi usage /mnt2/Media
Overall:
Device size: 18.19TiB
Device allocated: 9.65TiB
Device unallocated: 8.54TiB
Device missing: 0.00B
Device slack: 0.00B
Used: 8.98TiB
Free (estimated): 7.36TiB (min: 4.80TiB)
Free (statfs, df): 7.36TiB
Data ratio: 1.25
Metadata ratio: 2.00
Global reserve: 512.00MiB (used: 0.00B)
Multiple profiles: no
Data,RAID5: Size:7.71TiB, Used:7.17TiB (93.10%)
/dev/sdc 1.93TiB
/dev/sdh 1.93TiB
/dev/sda 1.93TiB
/dev/sdb 1.93TiB
/dev/sdd 1.93TiB
Metadata,RAID1: Size:9.00GiB, Used:8.12GiB (90.18%)
/dev/sdc 4.00GiB
/dev/sdh 4.00GiB
/dev/sda 3.00GiB
/dev/sdb 3.00GiB
/dev/sdd 4.00GiB
System,RAID1: Size:32.00MiB, Used:544.00KiB (1.66%)
/dev/sdc 32.00MiB
/dev/sdh 32.00MiB
Unallocated:
/dev/sdc 1.71TiB
/dev/sdh 1.71TiB
/dev/sda 1.71TiB
/dev/sdb 1.71TiB
/dev/sdd 1.71TiB
Thoughts on how I can proceed or how I can get more info about what is causing the failure
