I did a reinstall of rockstor and updated to 3.8-2. For the most part everything went smoothy a is working. However docker won’t start.
[root@san01 log]# systemctl status -l docker
docker.service - Docker Application Container Engine
Loaded: loaded (/etc/systemd/system/docker.service; enabled)
Active: failed (Result: exit-code) since Tue 2015-07-14 14:19:52 CDT; 26s ago
Docs: http://docs.docker.com
Process: 14771 ExecStart=/opt/rockstor/bin/docker-wrapper /mnt2/rockons (code=exited, status=1/FAILURE)
Main PID: 14771 (code=exited, status=1/FAILURE)
Jul 14 14:19:52 san01 docker-wrapper[14771]: Traceback (most recent call last):
Jul 14 14:19:52 san01 docker-wrapper[14771]: File “/opt/rockstor/bin/docker-wrapper”, line 37, in
Jul 14 14:19:52 san01 docker-wrapper[14771]: sys.exit(docker_wrapper.main())
Jul 14 14:19:52 san01 docker-wrapper[14771]: File “/opt/rockstor/src/rockstor/docker_wrapper.py”, line 29, in main
Jul 14 14:19:52 san01 docker-wrapper[14771]: run_command([DOCKER, ‘-d’, ‘-s’, ‘btrfs’, ‘-g’, mnt_pt])
Jul 14 14:19:52 san01 docker-wrapper[14771]: File “/opt/rockstor/src/rockstor/system/osi.py”, line 79, in run_command
Jul 14 14:19:52 san01 docker-wrapper[14771]: raise CommandException(out, err, rc)
Jul 14 14:19:52 san01 docker-wrapper[14771]: system.exceptions.CommandException: ’ time=“2015-07-14T14:19:52.163434527-05:00” level=info msg=“Listening for HTTP on unix (/var/run/docker.sock)” time=“2015-07-14T14:19:52.181625633-05:00” level=fatal msg=“Error starting daemon: Couldn’t create Tag store: EOF” '
Jul 14 14:19:52 san01 systemd[1]: docker.service: main process exited, code=exited, status=1/FAILURE
Jul 14 14:19:52 san01 systemd[1]: Unit docker.service entered failed state.
