@Marenz Hello again.
No, the built in replication feature is only inter Rockstor machines not intra machine.
Also note that Rockstor enforces unique subvol names within a system. So if you do end up doing a cron of sorts, ensure the target subvol has a system wide unique name.
Another note here is that if you simply want a snapshot to exist on 2 disks, i.e. the literal interpretation of:
The raid1 or 10 will do this underneath by ensuring all data chunks are on at lest 2 independent devices. But I’m assuming you mean from one pool to another, where each pool has a single disk in. With the context of ‘raid is not a backup’.
We do have the early stages of a realted feature planned by way of our roles mechanism. Take a look at the doc entry and the associated Web-UI page:
http://rockstor.com/docs/disks.html#disk-role-configuration
I.e. the archive role. If a single disk was the target intention.
There is also the clone mechanism that may be of interest. But this is within pool, not between pools.
