Added both appliances (old rockstor and new 4.0 as receiving). I get following when trying to replicate Configs-share (would like to just replicate whole pool).
[27/Nov/2020 17:52:01] ERROR [storageadmin.middleware:32] Exception occurred while processing a request. Path: /api/commands/refresh-share-state method: POST
[27/Nov/2020 17:52:01] ERROR [storageadmin.middleware:33] Error running a command. cmd = /usr/sbin/btrfs property get /mnt2/Data/.snapshots/Configs/Configs_4_replication_1 ro. rc = 1. stdout = [’’]. stderr = [‘ERROR: failed to open /mnt2/Data/.snapshots/Configs/Configs_4_replication_1: No such file or directory’, ‘ERROR: failed to detect object type: No such file or directory’, ‘usage: btrfs property get [-t ] []’, ‘’, ’ Gets a property from a btrfs object.’, ‘’, ’ If no name is specified, all properties for the given object are’, ’ printed.’, ’ A filesystem object can be a the filesystem itself, a subvolume,’, " an inode or a device. The ‘-t ’ option can be used to explicitly", ’ specify what type of object you meant. This is only needed when a’, ’ property could be set for more then one object type. Possible types’, ’ are s[ubvol], f[ilesystem], i[node] and d[evice].’, ‘’, ‘’]
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/core/handlers/base.py”, line 132, in get_response
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/views/decorators/csrf.py”, line 58, in wrapped_view
File “/opt/rockstor/eggs/Django-1.8.16-py2.7.egg/django/views/generic/base.py”, line 71, in view
File “/opt/rockstor/eggs/djangorestframework-3.1.1-py2.7.egg/rest_framework/views.py”, line 452, in dispatch
File “/opt/rockstor/eggs/djangorestframework-3.1.1-py2.7.egg/rest_framework/views.py”, line 449, in dispatch
return func(*args, **kwargs)
File “/opt/rockstor/src/rockstor/storageadmin/views/command.py”, line 348, in post
import_shares(p, request)
File “/opt/rockstor/src/rockstor/storageadmin/views/share_helpers.py”, line 86, in import_shares
shares_in_pool = shares_info(pool)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 721, in shares_info
snap_idmap[vol_id])
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 768, in parse_snap_details
writable = not get_property(full_snap_path, ‘ro’)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 1844, in get_property
o, e, rc = run_command(cmd)
File “/opt/rockstor/src/rockstor/system/osi.py”, line 176, in run_command
CommandException: Error running a command. cmd = /usr/sbin/btrfs property get /mnt2/Data/.snapshots/Configs/Configs_4_replication_1 ro. rc = 1. stdout = [’’]. stderr = [‘ERROR: failed to open /mnt2/Data/.snapshots/Configs/Configs_4_replication_1: No such file or directory’, ‘ERROR: failed to detect object type: No such file or directory’, ‘usage: btrfs property get [-t ] []’, ‘’, ’ Gets a property from a btrfs object.’, ‘’, ’ If no name is specified, all properties for the given object are’, ’ printed.’, ’ A filesystem object can be a the filesystem itself, a subvolume,’, " an inode or a device. The ‘-t ’ option can be used to explicitly", ’ specify what type of object you meant. This is only needed when a’, ’ property could be set for more then one object type. Possible types’, ’ are s[ubvol], f[ilesystem], i[node] and d[evice].’, ‘’, ‘’]
[27/Nov/2020 17:52:01] ERROR [storageadmin.middleware:32] Exception occurred while processing a request. Path: /api/commands/refresh-snapshot-state method: POST
File “/opt/rockstor/src/rockstor/storageadmin/views/command.py”, line 353, in post
import_snapshots(share)
File “/opt/rockstor/src/rockstor/storageadmin/views/share_helpers.py”, line 209, in import_snapshots
share.name)
File “/opt/rockstor/src/rockstor/fs/btrfs.py”, line 819, in snaps_info
stripped_path)
[27/Nov/2020 17:52:01] ERROR [smart_manager.replication.sender:74] Id: 00000000-0000-0000-0000-AC1F6B14152E-4. Failed to create snapshot: Configs_4_replication_1. Aborting… Exception: HTTPConnectionPool(host=‘127.0.0.1’, port=8000): Max retries exceeded with url: /api/shares/5/snapshots/Configs_4_replication_1 (Caused by <class ‘httplib.BadStatusLine’>: ‘’)
