Hi
Hello
I have exactly the same problem … is replication not working with 3.6-7 ?
Thanks for starting this discussion. Replication does work in 3.6-7. I use it actively for several shares on my personal Rockstor box. Occasionally, I see a failed send, but the next one succeeds.
10 minute replication frequency is not aggressive. If you can provide some more information, I’d be happy to help.
There are two log files for replication: /opt/rockstor/var/log/{supervisord_replication_stdout.log, supervisord_replication_stderr.log} If you can send the sender and receiver side log files, I’ll take a look. You can email them to support@rockstor.com
Also, on the sender side web-ui, if you click on “last backup” column, it will take you to the send trail of a particular share. If you hover on the ! icon in the status column, it will tell you the error.
let me know, happy to help!
Someone sent logs and I really appreciate it. I am guessing that person is not gps1539 as the logs showed failure on full replication and not incremental and it looks like that user never got a successful replication. Here’s the issue for the bug I tracked down from the sent logs. - https://github.com/rockstor/rockstor-core/issues/616
Just want to close loop on this topic. All github issues detailed and referenced are resolved and closed in subsequent Rockstor releases. Thank you for helping with this issue.
