Seems replication needs some work still, essentially the initial replication of a large share failed and now I’m stuck with a snapshot share I can’t delete from shares.
Rockstor 3.91-1
Ideally replication needs the ability to force start it now and also needs some work around recovering from a failed replication
Houston, we’ve had a problem.
Unknown client error doing a DELETE to /api/shares/.snapshots/ABxxxx-xxxx-xxx-xxx-xxxxxxxx_Backup1/Backup1_1_replication_1/force
I removed UUID but otherwise that’s the message
I’m starting to suspect the share name having the .snapshots is tripping up the webUI.
