@Schrauber, sorry for the late reply. Is it still stuck? Can you try restarting the rockstor service with this command as root: systemctl restart rockstor. You can also reboot, if that’s preferable. Let me know if it persists and I can give a small script to start fresh.
I restarted the Server several times. No change.
I also created a new share for rock-ons and set up the rock-ons service to this and deleted the old share. But also no change.
I have this exact same issue, anything that can be done to fix this? Or will plex be installing forever?
docker ps output:
[root@rockstor ~]# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
fc03adab4135 timhaak/plex “/start.sh” About an hour ago Up 2 minutes plex
