I tried to add some Rock-Ons @bug11 provides under GitHub - tronder88/rockons-extra
duplicatitronder88.json and owncloudtronder88.json were downloaded via wget to /opt/rockstor/rockons-metastore/.
When I hit [Update] in the Web-UI it tells me:
Error while processing Rock-on profile at
/opt/rockstor/rockons-metastore/owncloudtronder88.json. Lower level
exception: No JSON object could be decoded
This also happens for duplicatitronder88.json. Does anyone have an idea what I can do?
Thank you all.
[19/Apr/2016 09:04:24] DEBUG [storageadmin.util:48] Current Rockstor version: 3.8-12.11
[19/Apr/2016 09:04:24] ERROR [smart_manager.data_collector:320] failed to update Rock-on metadata. low-level exception: Error while processing Rock-on profile at /opt/rockstor/rockons-metastore/owncloudtronder88.json. Lower level exception: No JSON object could be decoded
[19/Apr/2016 09:04:37] ERROR [storageadmin.util:41] Error while processing Rock-on profile at /opt/rockstor/rockons-metastore/owncloudtronder88.json. Lower level exception: No JSON object could be decoded
[19/Apr/2016 09:04:37] ERROR [storageadmin.util:46] request path: /api/rockons/update method: POST data: <QueryDict: {}>
[19/Apr/2016 09:04:37] ERROR [storageadmin.util:47] exception: No JSON object could be decoded
File "/opt/rockstor/src/rockstor/storageadmin/views/rockon.py", line 375, in _get_available
ds = json.load(fo)
File "/usr/lib64/python2.7/json/__init__.py", line 290, in load
**kw)
File "/usr/lib64/python2.7/json/__init__.py", line 338, in loads
File "/usr/lib64/python2.7/json/decoder.py", line 365, in decode
File "/usr/lib64/python2.7/json/decoder.py", line 383, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
