I noticed the “custom_config” section in the owncloud rockon in the official registry.
The bellow snippet is what I’m looking at:
“custom_config”: {
“db_pw”: {
“description”: “Choose a secure password for the database admin user”,
“label”: “DB Password”
“db_user”: {
“description”: “Choose a administrator username for the OwnCloud database.”,
“label”: “DB User”
It’s from the following Rockon:
So, I understand that this sets some variables for the docker containers. I didn’t see any documentation on this section. Is there any documentation? I’m wondering how the custom_config variables work? For example, does one need to setup some specific variables to match in the docker file or a script with a specific name in the docker container that runs during it’s initial start?
Yeah, the custom_config object is a little bit of a special one.
The short answer to your questions–to the best of my knowledge–is that this object is dedicated only to two specific rock-ons: owncloud and openvpn. As a result, it doesn’t have any effect on other rock-ons.
To the best of my understanding of this part of Rockstor’s code and its evolution with time, I believe the custom_config object appeared in the early stages of the rock-on system in order to deal with “special” settings that these two rock-ons listed above required (such as db password and user-name, etc…). The related parts of the code is shown below:
and
As you can see, these are parts of custom logic to install and run these two rock-ons, and this may explain why there is no further documentation (as this object is limited to these two rock-ons).
As the rock-ons system grew, however, a lot more became possible with other, more specific objects such as options, environment, devices, cmd_arguments, and labels. As a result, you should be able to customize a rock-on definition a lot better with these objects now; further customization is on the way.
These objects are all documented in the repository README file in case you haven’t seen it:
If you are trying to write your own rock-on, please don’t hesitate to share your ideas and needs here… a lot of us should be able to help, and I myself would be very interested in hearing your needs as I’m currently working on further improving the rock-on system.
Thank you for the replies @vesper1978 and @Flox. I have received way more insight than ever expected. The reason for the custom_config has been lingering in the back of my mind for a while. I can now rest easy
