Since this looked like an interesting distraction, I created a minimal version of this. I installed it and it seems to work just fine this way. The only thing I omitted was the Base_url parameter, assuming it’s really for the home network or any other proxying will connect directly to it. I also picked postgres as the backend database, since it sees to enable more functionality and is recommended by them in the documentation when running on a NAS…
So, here it is:
"Mealie": {
"description": "Mealie is a self-hosted recipe manager and meal planner with a REST API backend and a reactive frontend application built in Vue for a pleasant user experience for the whole family.</p><p>Based on the <a href='https://github.com/mealie-recipes/mealie/pkgs/container/mealie' target='_blank'>official OCI image</a>, available for amd64 and arm64 architecture.</p>",
"version": "1.0",
"website": "https://mealie.io/",
"ui": {
"slug": ""
"containers": {
"mealie-db": {
"image": "postgres",
"tag": "17",
"launch_order": 1,
"volumes": {
"/var/lib/postgresql/data": {
"description": "Database storage for Mealie (Postgres).",
"label": "Database storage [e.g. mealie-pgdata]"
"environment": {
"POSTGRES_USER": {
"description": "Set the username for the postgres user.",
"label": "Postgres user [e.g. mealie]"
"POSTGRES_PASSWORD": {
"description": "Set the password for the postgres user.",
"label": "Postgres password [e.g. mealie]"
"POSTGRES_DB": {
"description": "Set the database name.",
"label": "Database name [e.g. mealie]"
"mealie-app": {
"image": "ghcr.io/mealie-recipes/mealie",
"tag": "latest",
"launch_order": 2,
"ports": {
"9000": {
"description": "Mealie Web Interface port.",
"label": "WebUI port [e.g. 9925]",
"host_default": 9925,
"protocol": "tcp",
"ui": true
"volumes": {
"/app/data/": {
"description": "Data storage for Mealie application.",
"label": "Mealie data [e.g. mealie-data]"
"opts": [
"-e",
"DB_ENGINE=postgres"
"-e",
"POSTGRES_SERVER=mealie-db"
"-e",
"POSTGRES_PORT=5432"
"environment": {
"ALLOW_SIGNUP": {
"description": "Allow new user registrations.",
"label": "Allow signup [e.g. false]"
"PUID": {
"description": "User ID to run the container as.",
"label": "PUID [e.g. 1000]"
"PGID": {
"description": "Group ID to run the container as.",
"label": "PGID [e.g. 1000]"
"POSTGRES_USER": {
"description": "Must match the database username set in mealie-db.",
"description": "Must match the database password set in mealie-db.",
"POSTGRES_DB": {
"description": "Must match the database name set in mealie-db.",
"container_links": {
"mealie-app": [
"name": "MealieAppToDB",
"source_container": "mealie-db"
If you want to play with it to see whether that works for you, follow the contribution guideline with creating the directory rockons-metastore in the appropriate place.
If you like it/it works for you, open a request (even with the minimal information you mentioned above) and I will submit it as a pull request. That way we have full attribution.
