I am attempting to install Rockstor for the first time and I am experiencing some challenges. After I create my bootable thumb drive using rufus, the only option it gives me is to install CentOS.
The end result pulls up an install menu for CentOS. If I move forward, a bunch of Linux icons appear and the install eventually times out. I never see the Rockstor load screen. Any ideas what I’m doing wrong?
Rockstor USB install disk using Rufus where it specifies a required setting for Rufus (otherwise it fails). Haven’t used it myself though but as @tobb555 intimated it has non sane defaults for Rockstor use.
@Twisted Welcome to the Rockstor community forum by the way.
Have you had a look at the docs Installation section? It has a couple of YouTube links and a link to our Rockstor in Virtual Machine Manager guide, all of which will should show what to expect, though they are all a little dated now. After having a look at these could you maybe describe more where things are diverging for you. You could even try an install in a virtual machine to familiarize yourself which what is ‘supposed’ to happen and there by get more of an idea of where things are not working out on your particular setup.
Hope that helps. Looks like you have ruled out the usb key writing software anyway.
