Hi All,
When following the instructions for ’ Install on Vanilla openSUSE/SuSE SLES’ and I get to this command
zypper in --no-recommends rockstor-4.1.0-0
I got this response
Mediavault:~ # zypper in --no-recommends rockstor-4.1.0-0
Loading repository data…
Reading installed packages…
Resolving package dependencies…
Problem: nothing provides ‘python-dbus-python’ needed by the to be installed rockstor-4.1.0-0.x86_64
Solution 1: do not install rockstor-4.1.0-0.x86_64
Solution 2: break rockstor-4.1.0-0.x86_64 by ignoring some of its dependencies
Choose from above solutions by number or cancel [1/2/c/d/?] ©:
I did quite a bit of searching on the net to not come up with any good solutions or hints about this. I decided to forge ahead and install but I am not sure of the impact that this will have on the stability of the install.
Thanks
Andrew
