Rockstor not starting, gpg decryption issue
Has anyone seen this after the latest update and reboot.
I did:
rm -rf /opt/rockstor/.venv
/opt/rockstor/build.sh
it errors with
gpg: A key for “rockstor@localhost” already exists
Sourcing /opt/rockstor.env
Password store initialized for rockstor@localhost
The generated password for python-keyring/rockstor/SECRET_KEY is:
XXXXXXXXXXXXXXXXXXX…
gpg: public key decryption failed: Invalid data
gpg: decryption failed: Invalid data
File “/opt/rockstor/.venv/bin/django-admin”, line 8, in
sys.exit(execute_from_command_line())
File “/opt/rockstor/.venv/lib/python3.11/site-packages/django/core/management/init.py”, line 442, in execute_from_command_line
utility.execute()
File “/opt/rockstor/.venv/lib/python3.11/site-packages/django/core/management/init.py”, line 382, in execute
settings.INSTALLED_APPS
File “/opt/rockstor/.venv/lib/python3.11/site-packages/django/conf/init.py”, line 102, in getattr
self._setup(name)
File “/opt/rockstor/.venv/lib/python3.11/site-packages/django/conf/init.py”, line 89, in _setup
self._wrapped = Settings(settings_module)
File “/opt/rockstor/.venv/lib/python3.11/site-packages/django/conf/init.py”, line 217, in init
mod = importlib.import_module(self.SETTINGS_MODULE)
File “/usr/lib64/python3.11/importlib/init.py”, line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1204, in _gcd_import
File “”, line 1176, in _find_and_load
File “”, line 1147, in _find_and_load_unlocked
File “”, line 690, in _load_unlocked
File “”, line 940, in exec_module
File “”, line 241, in _call_with_frames_removed
File “/opt/rockstor/src/rockstor/settings.py”, line 133, in
CLIENT_SECRET = keyring.get_password(“rockstor”, “CLIENT_SECRET”)
File “/opt/rockstor/.venv/lib/python3.11/site-packages/keyring/core.py”, line 63, in get_password
return get_keyring().get_password(service_name, username)
File “/opt/rockstor/.venv/lib/python3.11/site-packages/keyring_pass/init.py”, line 183, in get_password
ret = command(
File “/opt/rockstor/.venv/lib/python3.11/site-packages/keyring_pass/init.py”, line 26, in command
return subprocess.check_output(cmd, **kwargs)
File “/usr/lib64/python3.11/subprocess.py”, line 466, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “/usr/lib64/python3.11/subprocess.py”, line 571, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘[‘pass’, ‘show’, ‘python-keyring/rockstor/CLIENT_SECRET’]’ returned non-zero exit status 2.
@KeithMnemonic Hello again, and thanks for this report.
@Flox has just brought this to my attention as I’ve just seen this exact issue myself in an as-yet un-release installer, and I was working through what may have caused it - and a work-around also is the hope.
Linking back to the issue @Flox has linked to this forum post.
I’ll report back here if I find a work-around.
Could you indicate what OS version your install is based on, i.e. is this a Tumbleweed based install, or one built on one of the Leaps.
Hope that helps, at lease with some context. You report here has defintely help as I was concerned this was associated with an issue on our as-yet un-release installers - recently rebuild.
@KeithMnemonic & @Flox OK so we now have a proposed work-around, detailed in the previously referenced issue.
@KeithMnemonic could you confirm that the following restores your system to it’s prior function:
Executed as the ‘root’ user
cd
systemctl stop rockstor*
pass rm python-keyring/rockstor/CLIENT_SECRET
Answer “y” as in the following quote:
Are you sure you would like to delete python-keyring/rockstor/CLIENT_SECRET? [y/N] y
removed ‘/root/.password-store/python-keyring/rockstor/CLIENT_SECRET.gpg’
Restart rockstor’s systemd cascade
systemctl start rockstor-bootstrap.service
Note: Any Web-UI that remaind open during this failure will requrie a Browser refresh - even if the dashboard looks to have ‘woken-up’.
Let us know if this works in your instance, and we will then have further confirmation of at least a viable work-around. If all is well we can then approach a fix in an rpm update in due course. Likely making the associated code more robust to this type of failure.
For information and reference, for those who may have been impacted this:
This has been tracked down to a bug in gnupg. A fix was quickly provided by gnupg and included and released in the Tumbleweed and Slowroll repos. As result, if you encounter this issue, make sure to update your system packages and you should be good to go.
The problematic gpg2 version was: 2.5.7-1.1
The gpg2 version with the fix is: 2.5.7-2.1
More information can be found in our GitHub issue: rockstor-pre fails re password-store public key · Issue #3000 · rockstor/rockstor-core · GitHub
