Rockstor on odroid-xu4 with resilio sync and usb hdd
Hello together,
What you experts think, is the following a good idea?
I’m new to rockstor. I’d like to build a private NAS and thinking of the following combination:
  • odroid-xu4 as boad
  • 2 hdd either Seagate STEL8000200 Backup Plus Hub 8 TB or WD My Book Desktop 8 TB
  • resilio sync home
  1. Does rockstor run on odroid-xu4?
  2. Does btrfs get’s along with usb hard drives?
  3. Has the hardware enough power to run as a NAS + Resilio?
Will this work?
Thx for your help in advance!
Hello @funnyprinter,
Rockstor doesn’t currently run on ARM hardware. You’d need an Intel/AMD based system to run Rockstor.
Yes, it does.
@vesper1978 can you recommend any other similar board for this application?
Does rockstor support resilio?
@funnyprinter, I son’t have a recommendation for anything that would be similar in size. Maybe someone else will read this thread that can make one.
Rockstor has a Resilio Rock-On.
