malejo
(Maritza Johnson)
June 5, 2018, 1:04am
1
Prior to Rockstar I was running NAS4Free. I had the NAS4Free shares automatically mounted in Ubuntu via fstab. The shares were set up as follows.
//xxx.xxx.xxx.xxx/mnt2/tvshows/tv_shows /home/ritzie/tvshows cifs guest,uid=1000,iocharset=utf8 0 0
//xxx.xxx.xxx.xxx/mnt2/movies/movies1 /home/ritzie/movies cifs guest,uid=1000,iocharset=utf8 0 0
The file shares aren’t mounting. I think there is something wrong with this cifs guest,uid=1000,iocharset=utf8 0 0 but I’m not sure. Very new to CentOS.
malejo
(Maritza Johnson)
June 5, 2018, 2:40pm
2
I got further. //xxx.xxx.xxx.xxx/tvshows/tv_shows //home/ritzie/tvshows btrfs defaults 0 0
The mount point is under //tvshows/tv_shows however unbuntu comes back with the mount point doesn’t exist. TVshows being the pool and tv_shows shared
Hi @malejo ,
Your original fstab should have been fine - I’m not sure about the uid spec, but beyond that I don’t foresee any issues.
Are you sure that you have configured Samba/CIFS file sharing on your system shares? (Storage menu -> Samba)
Please note that by default, Shares is actually a pretty poor name for Rockstor’s shares, as they’re not actually shared, they are simply segmented slices of your filesystem for Rockstor to use as storage locations.
To share them, you must configure for sharing via SMB/CIFS, NFS, SFTP or AFP.
Cheers.
malejo
(Maritza Johnson)
June 6, 2018, 5:39pm
4
Hmm I’m able to access the shared drives via windows (r/w) but the shares will not mount in ubuntu. Keeps saying the share doesn’t exists.
Can you provide:
The related fstab contents
The exact error you’re receiving
Where you’re seeing the error (console, /var/log/messages, etc)
Output of an attempted manual mount, IE:
mount -t cifs //xxx.xxx.xxx.xxx/tvshows/tv_shows /home/ritzie/tvshows
malejo
(Maritza Johnson)
June 7, 2018, 11:18am
6
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a
device; this may be used with UUID= as a more robust way to name devices
that works even if disks are added and removed. See fstab(5).
/ was on /dev/sda1 during installation
UUID=928f1043-31cd-41b9-9837-b60e43095a18 / ext4 errors=remount-ro 0 1
swap was on /dev/sda5 during installation
UUID=53f65d61-8a25-46dd-9fdb-7c46fef2c5b5 none swap sw 0 0
#network drives
#//xxx.xxx.xxx.xxx/music /home/ritzie/music cifs guest,uid=1000,iocharset=utf8 0 0
#//xxx.xxx.xxx.xxx/movies /home/ritzie/movies cifs guest,uid=1000,iocharset=utf8 0 0
#//xxx.xxx.xxx.xxx/movies2 /home/ritzie/movies2 cifs guest,uid=1000,iocharset=utf8 0 0
#//xxx.xxx.xxx.xxx/movies3 /home/ritzie/movies3 cifs guest,uid=1000,iocharset=utf8 0 0
Retrying with upper case share name
mount error(6): No such device or address
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
seeing error in console when I use sudo mount -a in ubuntu.
mount error(13): Permission denied
Thanks @malejo ,
Please from the system you’re trying to mount the share on, also provide the output of:
smbclient -L xxx.xxx.xxx.xxx -U ritzie
This should tell us what shares are are available on xxx.xxx.xxx.xxx to your user.
malejo
(Maritza Johnson)
June 15, 2018, 4:41pm
8
My apologies, had an emergency and had to go out of town. I’ll get back to you with the info.
Any reason why you’re not using NFS? It’s much easier to setup via fstab.
malejo
(Maritza Johnson)
June 15, 2018, 6:54pm
10
I’m coming from nas4free. Drives were formatted as ufs or zfs . So I need to transfer my files to a new drive used for Rockstor with btrfs.
Does rockstor r/w to NFS?
malejo
(Maritza Johnson)
June 15, 2018, 7:55pm
11
output for smbclient
tv_shows Disk Samba-Export
IPC$ IPC IPC Service (Samba 4.7.1)
Domain=[HOME] OS=[Windows 6.1] Server=[Samba 4.7.1]
Server Comment
ROCKSTOR Samba 4.7.1
RT-AC5300-86D0 RT-AC5300-86D0
Workgroup Master
HOME RT-AC5300-86D0
