Sorry you ran into these issues and thank you for sending the logs, they are very helpful. I can see and to some extent, feel your pain looking at the logs
Looks like you ran into this bug: https://github.com/rockstor/rockstor-core/issues/579 It’s a bug in raid5/6. We’ll fix this in the next update that will be pushed in about a week or so. If you are able to delete your raid5/6 pools, I suggest you do that. It should help.
You are seeing the strangeness on the ui mainly because of consequences of the bug mentioned above. That triggered a lot of it.
I don’t see any other bugs from the logs, which is good. But again, sorry you ran into it in a big way. Other than waiting for the fix, I think you should delete all raid5/6 pools if you can and if not, may be do a re-install.
I don’t see any data relating to your temparature sensor tool, so you should probably continue using them and share your experience which will help us integrate relevant features into Rockstor.
Just want to close loop on this topic. All github issues detailed and referenced are resolved and closed in subsequent Rockstor releases. Thank you for helping with this issue.
