Hello. I will be short. I have this issue:
root@rockstor ~]# systemctl status smb.service
● smb.service - Samba SMB Daemon
Loaded: loaded (/etc/systemd/system/smb.service; enabled; vendor preset: disabled)
Active: failed (Result: exit-code) since Tue 2019-04-23 12:06:17 CEST; 20min ago
Process: 4402 ExecStart=/usr/sbin/smbd $SMBDOPTIONS (code=exited, status=1/FAILURE)
Main PID: 4402 (code=exited, status=1/FAILURE)
Apr 23 12:06:17 rockstor smbd[4402]: /usr/sbin/smbd: /usr/lib64/samba/libsecrets3-samba4.so: version SAMBA_4.7.1' not found (required by /usr/sbin/smbd) Apr 23 12:06:17 rockstor smbd[4402]: /usr/sbin/smbd: /usr/lib64/samba/libndr-samba-samba4.so: versionSAMBA_4.7.1’ not found (required by /usr/sbin/smbd)
Apr 23 12:06:17 rockstor smbd[4402]: /usr/sbin/smbd: /usr/lib64/samba/libsmbd-shim-samba4.so: version SAMBA_4.7.1' not found (required by /usr/sbin/smbd) Apr 23 12:06:17 rockstor smbd[4402]: /usr/sbin/smbd: /usr/lib64/samba/libsamba-debug-samba4.so: versionSAMBA_4.7.1’ not found (required by /usr/sbin/smbd)
Apr 23 12:06:17 rockstor smbd[4402]: /usr/sbin/smbd: /usr/lib64/samba/libpopt-samba3-samba4.so: version SAMBA_4.7.1' not found (required by /usr/sbin/smbd) Apr 23 12:06:17 rockstor smbd[4402]: /usr/sbin/smbd: /usr/lib64/samba/libsamba3-util-samba4.so: versionSAMBA_4.7.1’ not found (required by /usr/sbin/smbd)
Apr 23 12:06:17 rockstor smbd[4402]: /usr/sbin/smbd: /usr/lib64/samba/libsmbd-base-samba4.so: version `SAMBA_4.7.1’ not found (required by /usr/sbin/smbd)
Apr 23 12:06:17 rockstor systemd[1]: Failed to start Samba SMB Daemon.
Apr 23 12:06:17 rockstor systemd[1]: Unit smb.service entered failed state.
Apr 23 12:06:17 rockstor systemd[1]: smb.service failed.
I tried restarting, reinstalling, updating, and the problem is still there. The most annoying thing is that those files are where it’s saying that they are not there (maybe the error is because the version, IDK). And I don’t know what to do.
I hit this issue when trying to change my NFS sharings to SMB because I am having speed issues and I wanted to try if changing protocol could help. My speeds are now around 1 Mbps and is pretty disgusting. And I have now my WD DX4000 (maybe WD stands for Worst Devices) plugged straight to a 100 Mbps switch and my PC too to the same switch.
Can anyone help me?
Thank you, have a good files sharing.
