@magicalyak by way of addition to my last post I’ve finally managed to duplicate your issue as per my last post details.
I essentially jury rigged the url string to contain a name rather than a number and:
(Cron Daemon) to rockstor
18:15
File "/usr/lib64/python2.7/logging/handlers.py", line 76, in emit
if self.shouldRollover(record):
File "/usr/lib64/python2.7/logging/handlers.py", line 154, in shouldRollover
msg = "%s\n" % self.format(record)
File "/usr/lib64/python2.7/logging/__init__.py", line 724, in format
return fmt.format(record)
File "/usr/lib64/python2.7/logging/__init__.py", line 464, in format
record.message = record.getMessage()
File "/usr/lib64/python2.7/logging/__init__.py", line 324, in getMessage
msg = str(self.msg)
TypeError: __str__ returned non-string (type list)
Logged from file pool_scrub.py, line 83
msg = str(self.msg)
Logged from file pool_scrub.py, line 44
(Line numbers are a little different as this code is post code additions in the prior indicated pending pull request.)
with the equivalent log entries to the last ones posted by you:
[21/Aug/2017 18:15:01] DEBUG [scripts.scheduled_tasks.pool_scrub:92] task(7) finished with state(error).
[21/Aug/2017 18:20:02] ERROR [scripts.scheduled_tasks.pool_scrub:81] Failed to start scrub at pools/fakename/scrub
[21/Aug/2017 18:20:02] DEBUG [scripts.scheduled_tasks.pool_scrub:37] update_state constructs url=pools/fakename/scrub/status
[21/Aug/2017 18:20:02] ERROR [scripts.scheduled_tasks.pool_scrub:42] Failed to get scrub status at pools/fakename/scrub/status
[21/Aug/2017 18:20:02] DEBUG [scripts.scheduled_tasks.pool_scrub:92] task(7) finished with state(error).
So finally we got there.
Thanks @peter and @magicalyak and @Dragon2611 for sticking with this one.
I have now closed the following issue which was opened to track the development on the now solved:
“… returned non-string (type list)” mistery.
Thanks folks. We got there in the end.
