I thought I’d share some experience.
WIFI setup does not seem easy via WEB UI, well not even functional, well this was my expierience just recently.
I added a USB WIFI dongle to my system:
Bus 001 Device 003: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Maybe not the best, but I have an internal network and to get external connectivity I need to bridge via my desktop. So, I bought this cheap USB WIFI adapter.
After much searching and mucking around.
To get it to work I had to do the following (maybe I didn’t need some of this, but this was the process that worked.);
Thanks! helped me to get wireless up.
My problem is that i can’t really get a network cable to a smaller box i have for lab so i tried powerline adapter but it will not work good for me so wanted to try wireless as it’s not that far away.
One thing i find that was missing in your guide is that after installation of NetworkManager-wifi i had to reload/restart network manager for it to work with wifi adapters. Can be done with these lines:
