Hello,
I have today upgraded the Rockstor to version 3.9.2-57. Everything was fine until the first scheduled task with btrfs snapshot was launched. Since then, I am receiving the following e-mail on EVERY snapshot task (10 per hour):
opt/rockstor/eggs/setuptools-46.1.3-py2.7.egg/pkg_resources/py2_warn.py:21: UserWarning: Setuptools will stop working on Python 2
You are running Setuptools on Python 2, which is no longer supported and
SETUPTOOLS WILL STOP WORKING <<<
in a subsequent release (no sooner than 2020-04-20).
Please ensure you are installing
Setuptools using pip 9.x or later or pin tosetuptools<45
in your environment.
If you have done those things and are still encountering this message, please follow up at Sign in to GitHub · GitHub.
sys.version_info < (3,) and warnings.warn(pre + "*" * 60 + msg + "*" * 60)
My questions are:
- Does it mean, that the corresponding snapshots was not created?
- If it is only warning and all the snapshots in scheduled tasks are created just fine, how to disable it so that it stops spamming me all the time.
- Maybe it is not so easy, but is there a way I can solve this warining? For example by downgrading to older setuptools version? I am not sure if or how to do that, so that it will not collide with the rockstor installation.
Thank you very much for any advice.
