Hello everybody!
I come to this community to seek some advice. I will try to make my story short and to the point ![]()
I had media_pool with sdf (6To) and sdh (4To) in single disk.
The size of the pool was 8TB and the total used space in the pool is 7.08TB
Last week I bought another 8To disk that I added to my pool but I wanted to convert it to RAID1. So I started the conversion from the UI and this is the command that is running: “btrfs balance start -mconvert raid1 -dconvert raid1 -f /mnt2/media_pool”
Since the 24th (6 days ago), only 11% of the balance is done! When I check the new disk (sdj) only 834GB of data is present.
So my question is like all the other questions on the internet, is this normal? I know that a balance will be slow, but only 834GB of data wrote in 6 days is very very slow to me…
If I check iostat the speed is only 1.7MB write on the new disk:
Linux 4.12.4-1.el7.elrepo.x86_64 (rockstor.home) 10/30/2019 _x86_64_ (8 CPU)
avg-cpu: %user %nice %system %iowait %steal %idle
0.54 0.40 11.09 0.26 0.00 87.72
Device: tps kB_read/s kB_wrtn/s kB_read kB_wrtn
sda 0.00 0.06 0.00 37384 1580
sdb 0.04 1.32 0.04 769632 20848
sdc 0.00 0.09 0.00 52196 2092
sdd 0.04 1.31 0.03 765704 19004
sde 4.05 17.84 188.30 10408231 109878947
sdf 6.39 1679.18 1.00 979848208 581424
sdg 7.83 817.42 942.79 476989384 550145460
sdh 6.59 1678.68 1.00 979558376 581424
sdi 6.59 804.69 919.13 469560160 536335888
sdj 4.19 6.70 1695.85 3908408 989576004
Please note that I have no snapshots of this pool and I stopped all the services accessing this pool (beside plex, but it is not highly used).
Here is my version of Rockstor:
Installed Packages
Arch : x86_64
Version : 3.9.2
Release : 50
Repo : installed
From repo : Rockstor-Stable
Output of the following command:
btrfs balance status -v /mnt2/media_pool/
Balance on '/mnt2/media_pool/' is running
829 out of about 7324 chunks balanced (830 considered), 89% left
Dumping filters: flags 0xf, state 0x1, force is on
DATA (flags 0x100): converting, target=16, soft is off
METADATA (flags 0x100): converting, target=16, soft is off
SYSTEM (flags 0x100): converting, target=16, soft is off
There are no particular messages in dmesg:
kern :info : [Wed Oct 30 13:49:46 2019] BTRFS info (device sdg): relocating block group 10064043704320 flags data
kern :info : [Wed Oct 30 13:50:02 2019] BTRFS info (device sdg): found 2596 extents
kern :info : [Wed Oct 30 13:55:10 2019] BTRFS info (device sdg): found 2596 extents
kern :info : [Wed Oct 30 13:55:10 2019] BTRFS info (device sdg): relocating block group 10062969962496 flags data
kern :info : [Wed Oct 30 13:55:23 2019] BTRFS info (device sdg): found 2127 extents
kern :info : [Wed Oct 30 14:27:42 2019] BTRFS info (device sdg): found 2127 extents
kern :info : [Wed Oct 30 14:27:43 2019] BTRFS info (device sdg): relocating block group 10061896220672 flags data
kern :info : [Wed Oct 30 14:27:59 2019] BTRFS info (device sdg): found 2217 extents
So is it really normal to be so slow? One of my colleagues did a balance of a similar size in about 2 days.
Is something wrong? I norticular SMART error either…
In any cases, thank you very much for your advices!
Edit: I have found this post, so I disabled the quotas on that pool, I will let you know if it speeds up things.
George.
