I am looking at installing Rockstor as a replacement for my aging NAS. Is it safe to assume that since Rockstor supports Docker, that I can use additional applications from the Docker Hub to flesh out the server beyond the current list of rock-ons? If so, what is the best method to do accomplish this? Am I able to SSH into the server and run everything from the CLI? Or are there specific steps and/or limitations, prerequisites, etc?
@theimmortal Welcome to Rockstor community!
Your assumption is safe and correct. When you configure the Rock-on service with a Share, that Share is used by Docker with btrfs storage driver. For instance, if the Rock-on root share is called RockonRoot, docker daemon process will be:
[root@rockstor ~]# ps -ef | grep 'docker -d' | grep -v grep
root 13873 13872 0 Aug16 ? 00:24:07 /usr/bin/docker -d -s btrfs -g /mnt2/RockonRoot
Beyond that, there are no other restrictions. Just make sure you have enough space in your Rock-on root share. I also suggest using syslog logging driver or else the root share could balloon fast.
You can indeed ssh as the root user and do anything you wish. Docker daemon, aka Rock-on service can be restarted from the Web-ui or from the CLI using systemctl restart docker
I actually run this forum software(Discourse), Jenkins and a few other apps on a Rockstor box using CLI. You may have seen the wiki document about Rock-on framework improvements underway which would make it easy for advanced users to run arbitrary docker apps from the Web-UI.
I strongly encourage you to tinker with Rockstor as much as you want to and provide your feedback to help our ongoing effort.
Hi @suman how do you turn the syslog logging driver? Thanks
edit: just realized itâs docker specific.
As you can see my rockon root has balooned.
Is there a way to fix this? or I just have to rerun the container with the syslog driver?
also in Shares page, it does not reflect this balooning
Thanks for your assistance.
Cheers
Hi @kwetiaw,
can you post console output of this
btrfs qgroup show /mnt2/rockie/ -pc ? New share usage size now evaluetas snapshots too
Meanwhile @suman @phillxnet ,
while checking this found under my Rock-ons share we have some untracked snapshots:
root@rockstone:subvolumes# btrfs sub list /mnt2/rock -o
ID 1780 gen 6056 top level 1774 path rock/btrfs/subvolumes/2fa9c5fc7cbee14544a89bee1a87160918f32e00c660b8fdaa473ec406799d6d
ID 1781 gen 6057 top level 1774 path rock/btrfs/subvolumes/ac3135b453bfa094f109a870899af5d7441a72378627467a9120ade8c7922b23
ID 1782 gen 6058 top level 1774 path rock/btrfs/subvolumes/266acc0807ea4308345cbe625483f13603fcb587dfb4459c23ab7e0265ad7f0a
ID 1783 gen 6059 top level 1774 path rock/btrfs/subvolumes/e589529aaccbf60c4b80ee4add18514f6646b80eea524b2df735a0bf631f8c3f
ID 1784 gen 6060 top level 1774 path rock/btrfs/subvolumes/f588d23d4fa01654778918898c7428cfda49b34f6201cfe57991db6ab4a4893b
ID 1785 gen 6061 top level 1774 path rock/btrfs/subvolumes/fe114ccd76fdba2340667de00c3d1de578cad624e8e550f1bc19e4ac4d1ba04d
ID 1786 gen 6062 top level 1774 path rock/btrfs/subvolumes/cebe954360902cb7ae9804bd3dd5f12de08197f5d71bb0b94eac9e563d28cae9
ID 1787 gen 6063 top level 1774 path rock/btrfs/subvolumes/f852029df4dab486cc2dcbc2cb823ec57f864e950f1ec9c9814ec115d4bf84f2
ID 1788 gen 6064 top level 1774 path rock/btrfs/subvolumes/54642a45f18626924c7a68970d70dff4c3a3d3af953f9b0ead7d94706b4fa8e2
ID 1789 gen 8109 top level 1774 path rock/btrfs/subvolumes/06286ffd6f26d5bff6356d4510d9a80a7bdd2f898ee0267ba9dc9c9af6d82601
ID 1790 gen 6066 top level 1774 path rock/btrfs/subvolumes/d77427867c1e1c51667ff43f039a846aea9f94d43e5e9b52c3b9ddcb394006e8
ID 1791 gen 6067 top level 1774 path rock/btrfs/subvolumes/c5af9811e743715da13a4b0d8a233091808b7de99d1f7ed0b653c418c3beef1b
ID 1792 gen 6068 top level 1774 path rock/btrfs/subvolumes/c99582c31eb9f6bdb53d3c40b9c4d7d70c5aa6d8cd2c680fe57c251e287bd838
ID 1793 gen 6069 top level 1774 path rock/btrfs/subvolumes/e056f0c084f2bbcbb271c56103a7554ad0c4f5610afb5f4b16bd05660bd59348
ID 1794 gen 6071 top level 1774 path rock/btrfs/subvolumes/b8f8d24e359674f5870b77d95a2a8ff62f26e83d75ead68a56dd3451dd469bbb
ID 1795 gen 6072 top level 1774 path rock/btrfs/subvolumes/63c34bc5fffff44e8f91b5c2bd31bc0ebdc19f1a7351190487c06b28f0783239-init
ID 1796 gen 6112 top level 1774 path rock/btrfs/subvolumes/63c34bc5fffff44e8f91b5c2bd31bc0ebdc19f1a7351190487c06b28f0783239
All available under shares->snapshots, but missing qgroup assign to share (so not evaluated on share size): is that normal?
M.
this is the output
[root@nasitim ~]# btrfs qgroup show /mnt2/rockie/ -pc
qgroupid rfer excl parent child
0/5 16.00KiB 16.00KiB --- ---
0/257 16.00KiB 16.00KiB 2015/1 ---
0/258 2.95MiB 2.95MiB 2015/2 ---
0/259 16.00KiB 16.00KiB 2015/3 ---
0/260 14.15GiB 14.15GiB 2015/4 ---
0/275 16.00KiB 16.00KiB 2015/6 ---
0/276 16.00KiB 16.00KiB 2015/7 ---
0/277 1.23MiB 1.23MiB 2015/8 ---
0/278 16.00KiB 16.00KiB 2015/9 ---
0/279 3.56GiB 3.56GiB 2015/10 ---
0/280 178.09MiB 178.09MiB 2015/11 ---
0/281 2.60GiB 2.60GiB 2015/12 ---
0/290 16.00KiB 16.00KiB 2015/17 ---
0/293 16.00KiB 16.00KiB 2015/19 ---
0/294 16.00KiB 16.00KiB 2015/20 ---
0/303 267.40MiB 267.40MiB 2015/21 ---
0/304 2.11MiB 2.11MiB 2015/22 ---
0/305 64.22MiB 64.22MiB 2015/23 ---
0/306 132.69MiB 272.00KiB --- ---
0/307 132.69MiB 96.00KiB --- ---
0/308 115.00MiB 48.00KiB --- ---
0/309 115.00MiB 48.00KiB --- ---
0/310 115.00MiB 48.00KiB --- ---
0/311 115.00MiB 48.00KiB --- ---
0/312 115.00MiB 48.00KiB --- ---
0/313 115.00MiB 48.00KiB --- ---
0/314 115.00MiB 48.00KiB --- ---
0/315 115.00MiB 48.00KiB --- ---
0/316 115.00MiB 48.00KiB --- ---
0/317 115.00MiB 80.00KiB --- ---
0/318 127.47MiB 112.00KiB --- ---
0/319 127.47MiB 80.00KiB --- ---
0/320 127.47MiB 80.00KiB --- ---
0/321 127.47MiB 80.00KiB --- ---
0/322 127.47MiB 80.00KiB --- ---
0/323 375.95MiB 144.00KiB --- ---
0/324 375.97MiB 80.00KiB --- ---
0/325 375.97MiB 80.00KiB --- ---
0/326 375.97MiB 80.00KiB --- ---
0/327 375.97MiB 128.00KiB --- ---
0/328 381.60MiB 211.52MiB --- ---
0/329 16.00KiB 16.00KiB 2015/24 ---
0/355 4.08MiB 48.00KiB --- ---
0/356 4.08MiB 48.00KiB --- ---
0/357 4.08MiB 48.00KiB --- ---
0/358 4.08MiB 48.00KiB --- ---
0/359 24.51MiB 96.00KiB --- ---
0/360 24.51MiB 48.00KiB --- ---
0/361 24.51MiB 48.00KiB --- ---
0/362 24.51MiB 48.00KiB --- ---
0/363 131.25MiB 80.00KiB --- ---
0/364 131.25MiB 80.00KiB --- ---
0/365 131.25MiB 80.00KiB --- ---
0/366 131.25MiB 80.00KiB --- ---
0/367 131.25MiB 80.00KiB --- ---
0/368 131.27MiB 128.00KiB --- ---
0/369 263.69MiB 134.18MiB --- ---
0/370 2.93MiB 2.93MiB 2015/25 ---
0/371 16.00KiB 16.00KiB 2015/26 ---
0/372 1.11MiB 1.11MiB 2015/27 ---
0/373 514.68MiB 514.68MiB 2015/28 ---
0/374 127.47MiB 80.00KiB --- ---
0/375 127.47MiB 80.00KiB --- ---
0/376 127.47MiB 80.00KiB --- ---
0/377 127.47MiB 80.00KiB --- ---
0/378 242.28MiB 160.00KiB --- ---
0/379 242.29MiB 80.00KiB --- ---
0/380 242.29MiB 80.00KiB --- ---
0/381 242.29MiB 80.00KiB --- ---
0/382 242.29MiB 128.00KiB --- ---
0/383 242.32MiB 2.11MiB --- ---
0/384 131.25MiB 80.00KiB --- ---
0/385 131.25MiB 80.00KiB --- ---
0/386 131.25MiB 80.00KiB --- ---
0/387 131.25MiB 80.00KiB --- ---
0/388 131.25MiB 80.00KiB --- ---
0/389 131.25MiB 80.00KiB --- ---
0/390 131.27MiB 128.00KiB --- ---
0/391 171.87MiB 42.14MiB --- ---
0/393 4.84MiB 48.00KiB --- ---
0/394 4.84MiB 48.00KiB --- ---
0/395 4.84MiB 48.00KiB --- ---
0/396 4.84MiB 48.00KiB --- ---
0/397 4.84MiB 48.00KiB --- ---
0/398 25.16MiB 112.00KiB --- ---
0/399 25.16MiB 48.00KiB --- ---
0/400 25.16MiB 48.00KiB --- ---
0/401 25.16MiB 48.00KiB --- ---
0/402 85.07MiB 128.00KiB --- ---
0/403 85.10MiB 48.00KiB --- ---
0/404 85.10MiB 48.00KiB --- ---
0/405 85.10MiB 48.00KiB --- ---
0/406 85.10MiB 48.00KiB --- ---
0/407 85.10MiB 48.00KiB --- ---
0/408 85.10MiB 48.00KiB --- ---
0/409 85.10MiB 48.00KiB --- ---
0/410 85.10MiB 48.00KiB --- ---
0/411 85.10MiB 48.00KiB --- ---
0/412 85.10MiB 48.00KiB --- ---
0/415 195.32MiB 496.00KiB --- ---
0/417 195.32MiB 128.00KiB --- ---
0/418 195.32MiB 80.00KiB --- ---
0/419 195.32MiB 80.00KiB --- ---
0/420 195.32MiB 80.00KiB --- ---
0/421 195.38MiB 136.00KiB --- ---
0/422 229.14MiB 80.00KiB --- ---
0/423 229.14MiB 80.00KiB --- ---
0/424 229.14MiB 80.00KiB --- ---
0/425 229.14MiB 96.00KiB --- ---
0/426 229.16MiB 144.00KiB --- ---
0/427 237.07MiB 80.00KiB --- ---
0/428 237.07MiB 80.00KiB --- ---
0/429 237.07MiB 80.00KiB --- ---
0/430 237.07MiB 80.00KiB --- ---
0/431 237.07MiB 160.00KiB --- ---
0/432 261.62MiB 96.00KiB --- ---
0/433 261.64MiB 80.00KiB --- ---
0/434 261.66MiB 112.00KiB --- ---
0/435 261.66MiB 128.00KiB --- ---
0/436 261.66MiB 80.00KiB --- ---
0/437 261.66MiB 80.00KiB --- ---
0/438 261.66MiB 80.00KiB --- ---
0/439 261.66MiB 80.00KiB --- ---
0/440 261.66MiB 80.00KiB --- ---
0/441 261.66MiB 80.00KiB --- ---
0/442 261.66MiB 80.00KiB --- ---
0/443 261.66MiB 80.00KiB --- ---
0/444 261.66MiB 80.00KiB --- ---
0/445 349.04MiB 112.00KiB --- ---
0/446 349.04MiB 80.00KiB --- ---
0/447 349.04MiB 128.00KiB --- ---
0/448 349.05MiB 80.00KiB --- ---
0/449 349.05MiB 80.00KiB --- ---
0/450 349.05MiB 80.00KiB --- ---
0/454 127.47MiB 80.00KiB --- ---
0/455 127.47MiB 80.00KiB --- ---
0/456 127.47MiB 80.00KiB --- ---
0/457 127.47MiB 80.00KiB --- ---
0/458 127.47MiB 80.00KiB --- ---
0/459 127.47MiB 80.00KiB --- ---
0/460 127.47MiB 80.00KiB --- ---
0/461 360.39MiB 128.00KiB --- ---
0/462 360.40MiB 80.00KiB --- ---
0/463 360.40MiB 80.00KiB --- ---
0/464 360.40MiB 80.00KiB --- ---
0/465 360.40MiB 128.00KiB --- ---
0/466 360.46MiB 1.05MiB --- ---
0/474 82.47MiB 82.47MiB 2015/30 ---
0/475 127.07MiB 48.00KiB --- ---
0/477 127.07MiB 48.00KiB --- ---
0/478 127.07MiB 48.00KiB --- ---
0/479 319.35MiB 80.00KiB --- ---
0/480 319.35MiB 80.00KiB --- ---
0/481 319.35MiB 128.00KiB --- ---
0/482 326.73MiB 80.00KiB --- ---
0/483 326.73MiB 80.00KiB --- ---
0/484 326.73MiB 80.00KiB --- ---
0/485 326.71MiB 144.00KiB --- ---
0/486 326.71MiB 112.00KiB --- ---
0/487 326.71MiB 112.00KiB --- ---
0/488 326.71MiB 80.00KiB --- ---
0/489 326.71MiB 80.00KiB --- ---
0/490 326.71MiB 80.00KiB --- ---
0/491 326.71MiB 80.00KiB --- ---
0/492 326.71MiB 80.00KiB --- ---
0/493 326.71MiB 80.00KiB --- ---
0/494 326.71MiB 80.00KiB --- ---
0/495 326.71MiB 80.00KiB --- ---
0/496 326.71MiB 80.00KiB --- ---
0/497 326.71MiB 80.00KiB --- ---
0/498 338.60MiB 96.00KiB --- ---
0/499 338.60MiB 112.00KiB --- ---
0/500 369.30MiB 112.00KiB --- ---
0/501 369.31MiB 80.00KiB --- ---
0/502 369.31MiB 80.00KiB --- ---
0/503 369.31MiB 80.00KiB --- ---
0/504 369.31MiB 80.00KiB --- ---
0/505 369.31MiB 80.00KiB --- ---
0/506 369.31MiB 80.00KiB --- ---
0/507 463.12MiB 160.00KiB --- ---
0/508 467.15MiB 128.00KiB --- ---
0/509 467.15MiB 96.00KiB --- ---
0/510 467.15MiB 112.00KiB --- ---
0/511 470.79MiB 80.00KiB --- ---
0/512 470.79MiB 80.00KiB --- ---
0/513 470.79MiB 80.00KiB --- ---
0/514 553.43MiB 80.00KiB --- ---
0/515 553.43MiB 80.00KiB --- ---
0/516 553.43MiB 80.00KiB --- ---
0/517 553.43MiB 80.00KiB --- ---
0/518 131.25MiB 80.00KiB --- ---
0/519 131.25MiB 80.00KiB --- ---
0/520 131.25MiB 80.00KiB --- ---
0/521 131.25MiB 80.00KiB --- ---
0/522 131.25MiB 80.00KiB --- ---
0/523 131.25MiB 80.00KiB --- ---
0/524 131.25MiB 80.00KiB --- ---
0/525 131.25MiB 80.00KiB --- ---
0/528 131.27MiB 128.00KiB --- ---
0/529 201.44MiB 71.56MiB --- ---
0/530 349.05MiB 144.00KiB --- ---
0/531 371.27MiB 34.40MiB --- ---
0/534 205.92MiB 205.92MiB 2015/31 ---
0/535 127.47MiB 80.00KiB --- ---
0/536 127.47MiB 80.00KiB --- ---
0/537 127.47MiB 80.00KiB --- ---
0/538 127.47MiB 80.00KiB --- ---
0/539 127.47MiB 80.00KiB --- ---
0/540 127.47MiB 80.00KiB --- ---
0/541 127.47MiB 80.00KiB --- ---
0/542 127.47MiB 80.00KiB --- ---
0/543 316.62MiB 128.00KiB --- ---
0/544 316.64MiB 80.00KiB --- ---
0/545 316.64MiB 80.00KiB --- ---
0/546 316.64MiB 80.00KiB --- ---
0/547 316.64MiB 128.00KiB --- ---
0/548 316.70MiB 7.73MiB --- ---
0/549 14.54MiB 14.54MiB 2015/32 ---
0/552 47.57MiB 47.57MiB 2015/33 ---
0/553 16.00KiB 16.00KiB 2015/34 ---
0/554 127.47MiB 80.00KiB --- ---
0/555 127.47MiB 80.00KiB --- ---
0/556 127.47MiB 80.00KiB --- ---
0/557 318.14MiB 128.00KiB --- ---
0/559 318.16MiB 80.00KiB --- ---
0/560 318.16MiB 80.00KiB --- ---
0/561 318.16MiB 80.00KiB --- ---
0/576 129.07MiB 48.00KiB --- ---
0/577 129.07MiB 48.00KiB --- ---
0/578 305.40MiB 1.34MiB --- ---
0/579 320.85MiB 80.00KiB --- ---
0/580 320.85MiB 80.00KiB --- ---
0/581 320.85MiB 112.00KiB --- ---
0/582 328.11MiB 140.00KiB --- ---
0/583 328.09MiB 112.00KiB --- ---
0/584 328.09MiB 128.00KiB --- ---
0/585 328.09MiB 112.00KiB --- ---
0/586 328.09MiB 80.00KiB --- ---
0/587 328.09MiB 80.00KiB --- ---
0/588 328.09MiB 80.00KiB --- ---
0/589 328.09MiB 80.00KiB --- ---
0/590 328.09MiB 80.00KiB --- ---
0/591 328.09MiB 80.00KiB --- ---
0/592 328.09MiB 80.00KiB --- ---
0/593 531.22MiB 112.00KiB --- ---
0/594 531.23MiB 112.00KiB --- ---
0/595 531.23MiB 80.00KiB --- ---
0/596 531.23MiB 80.00KiB --- ---
0/597 531.23MiB 80.00KiB --- ---
0/598 531.23MiB 80.00KiB --- ---
0/599 531.23MiB 80.00KiB --- ---
0/600 572.91MiB 144.00KiB --- ---
0/601 583.01MiB 112.00KiB --- ---
0/602 573.76MiB 80.00KiB --- ---
0/603 573.76MiB 80.00KiB --- ---
0/604 573.76MiB 96.00KiB --- ---
0/605 573.78MiB 836.00KiB --- ---
0/607 318.16MiB 128.00KiB --- ---
0/608 318.20MiB 1.50MiB --- ---
0/609 131.25MiB 80.00KiB --- ---
0/610 131.25MiB 80.00KiB --- ---
0/611 131.25MiB 80.00KiB --- ---
0/612 131.25MiB 80.00KiB --- ---
0/613 182.68MiB 96.00KiB --- ---
0/614 182.68MiB 80.00KiB --- ---
0/615 182.68MiB 80.00KiB --- ---
0/616 182.68MiB 80.00KiB --- ---
0/617 182.68MiB 112.00KiB --- ---
0/618 201.63MiB 20.52MiB --- ---
0/619 24.51MiB 48.00KiB --- ---
0/620 24.51MiB 48.00KiB --- ---
0/621 24.51MiB 48.00KiB --- ---
0/622 24.51MiB 48.00KiB --- ---
0/623 24.51MiB 48.00KiB --- ---
0/624 108.72MiB 112.00KiB --- ---
0/626 108.72MiB 48.00KiB --- ---
0/627 108.72MiB 48.00KiB --- ---
0/628 108.72MiB 48.00KiB --- ---
0/631 108.72MiB 96.00KiB --- ---
0/632 126.30MiB 18.32MiB --- ---
0/634 127.07MiB 48.00KiB --- ---
0/635 127.07MiB 48.00KiB --- ---
0/636 185.36MiB 112.00KiB --- ---
0/637 185.36MiB 80.00KiB --- ---
0/638 185.36MiB 80.00KiB --- ---
0/639 185.36MiB 80.00KiB --- ---
0/640 185.36MiB 80.00KiB --- ---
0/641 185.36MiB 96.00KiB --- ---
0/642 468.43MiB 96.00KiB --- ---
0/643 469.96MiB 80.00KiB --- ---
0/644 460.52MiB 80.00KiB --- ---
0/645 460.52MiB 80.00KiB --- ---
0/646 460.52MiB 96.00KiB --- ---
0/647 460.54MiB 80.00KiB --- ---
0/648 460.54MiB 80.00KiB --- ---
0/649 460.54MiB 96.00KiB --- ---
0/650 460.54MiB 80.00KiB --- ---
0/651 460.54MiB 80.00KiB --- ---
0/652 460.54MiB 80.00KiB --- ---
0/661 229.14MiB 80.00KiB --- ---
0/662 229.14MiB 96.00KiB --- ---
0/663 229.16MiB 144.00KiB --- ---
0/664 236.99MiB 80.00KiB --- ---
0/665 236.99MiB 80.00KiB --- ---
0/666 236.99MiB 80.00KiB --- ---
0/667 236.99MiB 80.00KiB --- ---
0/668 270.89MiB 80.00KiB --- ---
0/669 270.89MiB 80.00KiB --- ---
0/670 270.93MiB 80.00KiB --- ---
0/671 270.93MiB 112.00KiB --- ---
0/672 270.93MiB 112.00KiB --- ---
0/673 270.93MiB 112.00KiB --- ---
0/674 270.94MiB 80.00KiB --- ---
0/675 270.94MiB 80.00KiB --- ---
0/676 270.94MiB 80.00KiB --- ---
0/677 270.94MiB 80.00KiB --- ---
0/678 270.94MiB 80.00KiB --- ---
0/679 318.39MiB 144.00KiB --- ---
0/680 318.41MiB 80.00KiB --- ---
0/681 318.43MiB 96.00KiB --- ---
0/682 318.43MiB 80.00KiB --- ---
0/683 318.43MiB 80.00KiB --- ---
0/684 318.43MiB 80.00KiB --- ---
0/689 56.00KiB 56.00KiB 2015/35 ---
0/690 195.32MiB 80.00KiB --- ---
0/691 195.38MiB 136.00KiB --- ---
0/692 229.11MiB 80.00KiB --- ---
0/693 229.11MiB 80.00KiB --- ---
0/694 229.11MiB 80.00KiB --- ---
0/695 229.11MiB 80.00KiB --- ---
0/696 229.11MiB 80.00KiB --- ---
0/697 229.11MiB 80.00KiB --- ---
0/698 229.11MiB 80.00KiB --- ---
0/699 229.11MiB 80.00KiB --- ---
0/700 229.11MiB 80.00KiB --- ---
0/701 229.21MiB 112.00KiB --- ---
0/702 229.21MiB 192.00KiB --- ---
0/703 377.72MiB 80.00KiB --- ---
0/705 377.72MiB 80.00KiB --- ---
0/731 32.00KiB 32.00KiB 2015/36 ---
0/732 195.39MiB 480.00KiB --- ---
0/733 195.40MiB 128.00KiB --- ---
0/734 195.40MiB 80.00KiB --- ---
0/735 195.40MiB 80.00KiB --- ---
0/736 195.40MiB 80.00KiB --- ---
0/737 195.46MiB 152.00KiB --- ---
0/738 229.25MiB 80.00KiB --- ---
0/739 229.25MiB 80.00KiB --- ---
0/740 229.25MiB 80.00KiB --- ---
0/741 229.52MiB 96.00KiB --- ---
0/742 229.52MiB 112.00KiB --- ---
0/743 229.66MiB 112.00KiB --- ---
0/744 229.66MiB 112.00KiB --- ---
0/745 229.66MiB 112.00KiB --- ---
0/746 229.66MiB 80.00KiB --- ---
0/747 229.66MiB 80.00KiB --- ---
0/748 229.66MiB 80.00KiB --- ---
0/749 229.66MiB 80.00KiB --- ---
0/750 265.68MiB 80.00KiB --- ---
0/751 265.68MiB 80.00KiB --- ---
0/752 265.72MiB 80.00KiB --- ---
0/753 265.72MiB 112.00KiB --- ---
0/754 265.73MiB 112.00KiB --- ---
0/755 265.73MiB 112.00KiB --- ---
0/756 265.73MiB 80.00KiB --- ---
0/757 265.73MiB 80.00KiB --- ---
0/758 265.73MiB 80.00KiB --- ---
0/759 265.73MiB 80.00KiB --- ---
0/760 265.73MiB 80.00KiB --- ---
0/761 495.52MiB 96.00KiB --- ---
0/762 496.93MiB 80.00KiB --- ---
0/763 476.03MiB 80.00KiB --- ---
0/764 476.03MiB 80.00KiB --- ---
0/765 476.04MiB 80.00KiB --- ---
0/766 476.04MiB 80.00KiB --- ---
0/767 476.04MiB 80.00KiB --- ---
0/768 476.04MiB 112.00KiB --- ---
0/769 476.04MiB 80.00KiB --- ---
0/770 476.04MiB 80.00KiB --- ---
0/771 476.04MiB 80.00KiB --- ---
0/795 460.54MiB 144.00KiB --- ---
0/796 504.35MiB 48.73MiB --- ---
0/801 195.04MiB 512.00KiB --- ---
0/802 195.04MiB 128.00KiB --- ---
0/803 182.97MiB 80.00KiB --- ---
0/804 182.97MiB 80.00KiB --- ---
0/805 182.99MiB 80.00KiB --- ---
0/806 182.99MiB 80.00KiB --- ---
0/807 182.99MiB 80.00KiB --- ---
0/808 184.54MiB 80.00KiB --- ---
0/809 184.54MiB 80.00KiB --- ---
0/810 184.54MiB 80.00KiB --- ---
0/811 184.54MiB 80.00KiB --- ---
0/812 184.54MiB 112.00KiB --- ---
0/813 184.54MiB 112.00KiB --- ---
0/814 504.49MiB 112.00KiB --- ---
0/816 548.99MiB 96.00KiB --- ---
0/817 549.02MiB 80.00KiB --- ---
0/818 549.02MiB 80.00KiB --- ---
0/819 549.02MiB 80.00KiB --- ---
0/820 549.02MiB 80.00KiB --- ---
0/821 549.02MiB 80.00KiB --- ---
0/822 549.02MiB 80.00KiB --- ---
0/823 549.02MiB 80.00KiB --- ---
0/824 0.00B 0.00B --- ---
0/825 0.00B 0.00B --- ---
0/826 549.04MiB 112.00KiB --- ---
0/827 550.36MiB 3.36MiB --- ---
2015/1 16.00KiB 16.00KiB --- 0/257
2015/2 2.95MiB 2.95MiB --- 0/258
2015/3 16.00KiB 16.00KiB --- 0/259
2015/4 14.15GiB 14.15GiB --- 0/260
2015/6 16.00KiB 16.00KiB --- 0/275
2015/7 16.00KiB 16.00KiB --- 0/276
2015/8 1.23MiB 1.23MiB --- 0/277
2015/9 16.00KiB 16.00KiB --- 0/278
2015/10 3.56GiB 3.56GiB --- 0/279
2015/11 178.09MiB 178.09MiB --- 0/280
2015/12 2.60GiB 2.60GiB --- 0/281
2015/17 16.00KiB 16.00KiB --- 0/290
2015/19 16.00KiB 16.00KiB --- 0/293
2015/20 16.00KiB 16.00KiB --- 0/294
2015/21 267.40MiB 267.40MiB --- 0/303
2015/22 2.11MiB 2.11MiB --- 0/304
2015/23 64.22MiB 64.22MiB --- 0/305
2015/24 16.00KiB 16.00KiB --- 0/329
2015/25 2.93MiB 2.93MiB --- 0/370
2015/26 16.00KiB 16.00KiB --- 0/371
2015/27 1.11MiB 1.11MiB --- 0/372
2015/28 514.68MiB 514.68MiB --- 0/373
2015/30 82.47MiB 82.47MiB --- 0/474
2015/31 205.92MiB 205.92MiB --- 0/534
2015/32 14.54MiB 14.54MiB --- 0/549
2015/33 47.57MiB 47.57MiB --- 0/552
2015/34 16.00KiB 16.00KiB --- 0/553
2015/35 56.00KiB 56.00KiB --- 0/689
2015/36 32.00KiB 32.00KiB --- 0/731
Having some tests over Rock-ons share had expected behaviour:
fallocate -l 100M file_ato create a 100MB file - got a snapshot so that 100MB on total size, but not exclusive size
- deleted file_a and snapshot got updated with 100MB both total and exclusive size
fallocate -l 100M file_bto have another file and show expected Dashboard widget and share page behaviour
Snapshot has 100/100MB size â OK (different sizes because of metadata, normal)
Dashboard widget having 100 MB blue (file_b, available in Rock-ons share) + light-blue 100MB (deleted 100MB file_a, not available in Rock-ons share, but under snapshot ârock_test4â from previous image)
Back to @kwetiaw first image (small line with share data), I suppose no update to latest Rockstor (one column missing), so not related to recent updates.
Your output is quite normal except all those âorphansâ snapshots (see my previous post): can you run btrfs sub list /mnt2/rockie -o ? Once again @phillxnet @suman I think we have a potential flaw not tracking some snapshots created every time users had a docker image
Dashboard widget @kwetiaw: that 5G is a âsoft limitâ (we donât force share content to be <= share size), so probably you had lot of data (although I canât understand mismatching on share details page â that code has been changed with last updates, but please wait, probably some changes required)
M.
EDIT:
[Cultural OT]
Probably reading this youâll notice my share screenshot has 5am time - yep, I woke up early and couldnât sleep anymore
- , and while testing this had some googling on UTC time: do you know why we call it UTC instead of CUT although its full name is Coordinated Universal Time ?? â UTC, not CUT or TUC
Have a good day ![]()
[/Cultural OT]
I recently started with rockstor, so I havent signed up with stable release or anything yet. Iâm currently at ROCKSTOR 3.8.16-1. Shouldâve mention it in my post.
It is also worth mentioning that I have several docker apps running outside what is available at Rock-ons list. I created the shares via rockon GUI and then running the docker image via CLI. Such as Piwigo, PlexRequests, lazylibrarian and so forth. Is this the right thing to do?
[root@nasitim ~]# btrfs sub list /mnt2/rockie -o
ID 306 gen 8733 top level 305 path rockie/btrfs/subvolumes/ffa920a196d9f4fb1df8a826c22e55f9bbf14150655af46235ad5a7d172a3e89
ID 307 gen 8733 top level 305 path rockie/btrfs/subvolumes/5e951a8003f1491280987d015d34f51bb6c7ffc2ba34cb4c82d853727b115494
ID 308 gen 8733 top level 305 path rockie/btrfs/subvolumes/1764a46f680fa4e352fc3fe8f9f75b930fbc3be69f7b26fffa47cc279852ad7d
ID 309 gen 8733 top level 305 path rockie/btrfs/subvolumes/31c87eb8694dc4d4ca1db010903125a65ccfeb287bade202695985754e22f31d
ID 310 gen 8733 top level 305 path rockie/btrfs/subvolumes/1d6f52380bd7170c434753d1023343c692b49f48692a8e13cf6a4eb56c291206
ID 311 gen 8733 top level 305 path rockie/btrfs/subvolumes/b65a28050091d7d01d2162a54aa5b5b8e6600438e59b04041f3e981e226dfe7f
ID 312 gen 8733 top level 305 path rockie/btrfs/subvolumes/2ec22984e726771300ad515aea5b367e659cfb7efad1be3b06c52e3e1f0991db
ID 313 gen 8733 top level 305 path rockie/btrfs/subvolumes/3b717f8ca4b7f875f21db2923e6d64ee2e9a938e4338ccb640f67851f2d2d5c0
ID 314 gen 8733 top level 305 path rockie/btrfs/subvolumes/691da379d1f330eb7d38410efc74910300b98225502c9723152f868cc1413027
ID 315 gen 8733 top level 305 path rockie/btrfs/subvolumes/2bfd827fa448363e9eb751aaefe9635c871c4a88b078e87337394f9d06b50cb8
ID 316 gen 8733 top level 305 path rockie/btrfs/subvolumes/0e5083124e7f146f44182a9bf308e90a98074f5ddd62d5dc7e0914981b5a33cf
ID 317 gen 8733 top level 305 path rockie/btrfs/subvolumes/3331731f5f4aeee58e409df0eb249a0133f3ea524519daebd68ef9d581ae660c
ID 318 gen 8733 top level 305 path rockie/btrfs/subvolumes/12129279a4ae5983cddc3050f9c44670fe1b4a6914c81801a49b9a6e2fca29aa
ID 319 gen 8733 top level 305 path rockie/btrfs/subvolumes/cd2899830fdfcf60b0298536676fd678cdcbd34b623f08b23bf1ed28d844ac6d
ID 320 gen 8733 top level 305 path rockie/btrfs/subvolumes/a34f5ee375923256a8006c7051b592d340a7fe0e5e74583d92d02b2d370999d9
ID 321 gen 8733 top level 305 path rockie/btrfs/subvolumes/a7b9374e853973bcd68d14a79ea030be01e1129694e8fdba7bc2e8079e7ac20e
ID 322 gen 8733 top level 305 path rockie/btrfs/subvolumes/959466bd2e25e42df88418a3893c19c8675fe351d1fd21d4db75822842ee73df
ID 323 gen 8733 top level 305 path rockie/btrfs/subvolumes/7a82e14a17bcf9ecc0d2989f5d798db3401f03d3ce012f97c48053914f936f34
ID 324 gen 8733 top level 305 path rockie/btrfs/subvolumes/2a76c0c07876317d9bb1ed0f6c6aa50142103d738e6d070c2cbe1e7cb38732e5
ID 325 gen 8733 top level 305 path rockie/btrfs/subvolumes/36bcc55291ee9d440964b9587a73518306bef959d19943edcce69709cec0a2cf
ID 326 gen 8733 top level 305 path rockie/btrfs/subvolumes/908cbdea5ce6108195dc0a7a5c1887904f6b8148f9480666c552590acb663426
ID 327 gen 8733 top level 305 path rockie/btrfs/subvolumes/0bd8bdf867eee31ffeacf04976cdcb5666191f26429f892c0e4626cacfd04009-init
ID 328 gen 8733 top level 305 path rockie/btrfs/subvolumes/0bd8bdf867eee31ffeacf04976cdcb5666191f26429f892c0e4626cacfd04009
ID 355 gen 8724 top level 305 path rockie/btrfs/subvolumes/4716759c283be395514b813039c6718b1d02a91213782981f22a90cfb2bb51ea
ID 356 gen 8724 top level 305 path rockie/btrfs/subvolumes/9cd0a1be3282216e3776455db13a69bfe616c3f1c565e717043ee0af40eafff8
ID 357 gen 8724 top level 305 path rockie/btrfs/subvolumes/40cf5cd85850fc40b377152af116556f00dcd05a2906979f7b9a0206a0b9db4e
ID 358 gen 8724 top level 305 path rockie/btrfs/subvolumes/72525181f5fc509025d8b26e8a5f5b556dbfe1948d1fb1f1fa939e48d11d8251
ID 359 gen 8733 top level 305 path rockie/btrfs/subvolumes/735c09d2586e593d1e2d7b78a14e91d0ecfd0e624701522ecd9a62cbe975ab70
ID 360 gen 8733 top level 305 path rockie/btrfs/subvolumes/d0f6b47e707e142298c6eea66b4400e9045e49e6d699095b8aabfa4bc1d8df48
ID 361 gen 8733 top level 305 path rockie/btrfs/subvolumes/86b588402de0f34b8ab1d3a8897efdb197f2a16309b35a28f235153b3484921c
ID 362 gen 8733 top level 305 path rockie/btrfs/subvolumes/7ca7ac6a1a0ab0c2a445929dd8ab40f6093de742427a34d1fc6ba53221e637c9
ID 363 gen 8733 top level 305 path rockie/btrfs/subvolumes/0ce12130df4fcf91d851b7ad56a3a56b3d6a6a93d005f667def071487f95dde6
ID 364 gen 8733 top level 305 path rockie/btrfs/subvolumes/5726d0582a15480970bd93ff2ff81c34dff30834310f1f8a10a41486c4fc2a15
ID 365 gen 8733 top level 305 path rockie/btrfs/subvolumes/b9b096672007021ac4ca8ec9c03cc073d322be0841372dab63f4e4f319ea0684
ID 366 gen 8733 top level 305 path rockie/btrfs/subvolumes/d77365ee23f8d411bbe2532842abdcfe5364b2579d78d96e837d87923215fc34
ID 367 gen 8733 top level 305 path rockie/btrfs/subvolumes/c447e4ed814a0b8e1d9e94fb9199a7a3c9cb74886fbace1d3b63950b2e2563ff
ID 368 gen 8733 top level 305 path rockie/btrfs/subvolumes/c5cf3f50687e70090d5104a6eeeb4210c20d3cbf6c50dc0102338beae11b382f-init
ID 369 gen 8733 top level 305 path rockie/btrfs/subvolumes/c5cf3f50687e70090d5104a6eeeb4210c20d3cbf6c50dc0102338beae11b382f
ID 374 gen 8733 top level 305 path rockie/btrfs/subvolumes/24c00bfc855c62477625ccc0ba7ad3c9cc9aea8c32373ed2c1788589ff843a3b
ID 375 gen 8733 top level 305 path rockie/btrfs/subvolumes/488bcf6fe5c5dfcf93953df0f49cd070a66b7b188ffcfe92250617eca8f80c45
ID 376 gen 8733 top level 305 path rockie/btrfs/subvolumes/eb2772c20edc587f51d962a29b31f017a0b4926c9d7d2bcafeac116f70aa50f5
ID 377 gen 8733 top level 305 path rockie/btrfs/subvolumes/969a820bc629cb3d65883c1f1ba43245f1942210e65435eaa92c0bcbb5861246
ID 378 gen 8733 top level 305 path rockie/btrfs/subvolumes/5bcda888ef314595c6d2b9d4224e5ed4d60ae6209cf809d190f807b65fc866c5
ID 379 gen 8733 top level 305 path rockie/btrfs/subvolumes/51382848c6bc683d9f003129a5f61b00dbb1b86f5fcef107fa2bb19bf0f05740
ID 380 gen 8733 top level 305 path rockie/btrfs/subvolumes/cec6686e6712611e3cf5a5daa1b4d5e752952c1fb32a7fb8f761ab8bab339674
ID 381 gen 8733 top level 305 path rockie/btrfs/subvolumes/351d4ada31ddd8d0a0729a19b9af5efa5cd88449a0db923dcb50207bb4b2974c
ID 382 gen 8733 top level 305 path rockie/btrfs/subvolumes/5d2ea8f1930e712cb411e4c11689a611d034226a262434222f14377f3cf9a44d-init
ID 383 gen 8733 top level 305 path rockie/btrfs/subvolumes/5d2ea8f1930e712cb411e4c11689a611d034226a262434222f14377f3cf9a44d
ID 384 gen 8733 top level 305 path rockie/btrfs/subvolumes/65ca6f191be73f6fd5b8c1b068ef131fb73ad3e0c88097fd961409c994d6604c
ID 385 gen 8733 top level 305 path rockie/btrfs/subvolumes/17b551b100976c10b4d6475542ae5085385d435342e22778774f9dc4e2c48a4b
ID 386 gen 8733 top level 305 path rockie/btrfs/subvolumes/bad75af5967dab1cd2dfd03a37a31d6e49fb0962dd6e76c2cd5d4782bfafcaf8
ID 387 gen 8733 top level 305 path rockie/btrfs/subvolumes/12f473921d9590fdbd01c2ee09508331ac4902ae9b6289c4b9077a76d229e7f6
ID 388 gen 8733 top level 305 path rockie/btrfs/subvolumes/fe6a0266dd060c75e9a2afe3a224c90fbbfc8864d3d59a74ce830519833f293c
ID 389 gen 8733 top level 305 path rockie/btrfs/subvolumes/abf2e8ecf198ddc6adef56435dbcdff6860edb2ef401f5bfe34a34c2e2b245be
ID 390 gen 8733 top level 305 path rockie/btrfs/subvolumes/02fe71761790644de24cd3b42468e04fca1cb9fa82d5b01dccf7b945277d454d-init
ID 391 gen 8733 top level 305 path rockie/btrfs/subvolumes/02fe71761790644de24cd3b42468e04fca1cb9fa82d5b01dccf7b945277d454d
ID 393 gen 8724 top level 305 path rockie/btrfs/subvolumes/9a4a6cc8f8d2d9d43df907d54c6476ffd49639ee29f5f3008e0cda91039a0d44
ID 394 gen 8724 top level 305 path rockie/btrfs/subvolumes/39f841421c4eff22b39233607f48399cc74247531a5a586422f538c24a1214cb
ID 395 gen 8724 top level 305 path rockie/btrfs/subvolumes/f401ffa018d67c71522e9ce941fae422eae1b747ff1a9ca744efd74ffd6a9e3e
ID 396 gen 8724 top level 305 path rockie/btrfs/subvolumes/f24f8f0e97a136edd1ed8e747ae097f2b2818daffa0c496bfcabd76c4476fbae
ID 397 gen 8724 top level 305 path rockie/btrfs/subvolumes/37830475a88627444f7d015836d2eacc788ec70e920eb9febe4999484f92d129
ID 398 gen 8724 top level 305 path rockie/btrfs/subvolumes/2fa76148bcac6a67ccf42d171670044c5e8f7d497ccc7c3a7f3adbf8bc98895f
ID 399 gen 8724 top level 305 path rockie/btrfs/subvolumes/f8757f8560a34ebf0f23dc9a03ed7859016dcb7e3f2a682996c6cf44b4eda772
ID 400 gen 8724 top level 305 path rockie/btrfs/subvolumes/35ba85b0ab12116686fa4e5eca4b939617633ea6c9733d1dabafa1a55cd86e99
ID 401 gen 8724 top level 305 path rockie/btrfs/subvolumes/85505f950819f64cc869c370acf0e62499ad563c79a11fcdce568927ddfd4cda
ID 402 gen 8724 top level 305 path rockie/btrfs/subvolumes/8d53989ceb17be743acec8b5ccf00e56a8130ad4a84c47cad5ebc22ec33cc79e
ID 403 gen 8724 top level 305 path rockie/btrfs/subvolumes/dd369400fabf4077e2a4b444d2c1c6c40fd66dbb4524af2799dac3a84dfeb616
ID 404 gen 8724 top level 305 path rockie/btrfs/subvolumes/d34cd6ab8fc4becefdf7101c4dc44dbfa4724282ab4fc134e316bb57b20fcc9f
ID 405 gen 8724 top level 305 path rockie/btrfs/subvolumes/96bfc1ada66355f0f62d792009b4ff557e2a52b902d628fce9d928b776bfc56e
ID 406 gen 8724 top level 305 path rockie/btrfs/subvolumes/7bd7eca3f20e31f46e9eb8b728ff290d19224e0e2c3b98efaa2d898e660789f4
ID 407 gen 8724 top level 305 path rockie/btrfs/subvolumes/eb8ab3339267f80c2e97d61330386cbc7edc4a09a0081c5ed524f9f0443f8ce9
ID 408 gen 8724 top level 305 path rockie/btrfs/subvolumes/5005b3c5d54f672edf9a79feb75d4a5387e46ac7fdafba4183ec707d7b1731c5
ID 409 gen 8724 top level 305 path rockie/btrfs/subvolumes/3bbf9a21c96d6814464fd108d0201644f4951b476b810283dc953c45b2e66e2e
ID 410 gen 8724 top level 305 path rockie/btrfs/subvolumes/984544ba066cdd43a9b0509d775f3e5ababb5a85d7a5fc077cf14a22c15c6bf4
ID 411 gen 8724 top level 305 path rockie/btrfs/subvolumes/95106d92a5c29efd5f3e79d1cb2bd37d5df8c0bdbbc4642224fd27f1821d0ce2
ID 412 gen 8724 top level 305 path rockie/btrfs/subvolumes/4d076ec450345f9e80edfd01cb7fe43b89f8155e32073f1e89b577c9e712f074
ID 415 gen 8739 top level 305 path rockie/btrfs/subvolumes/01a44504c48d528cf64d2691e5d362f328962560eb0427c6f53fb2300df87bd9
ID 417 gen 8739 top level 305 path rockie/btrfs/subvolumes/97e9fc98a8bdb50045400594330b50d79ae6e8b3bf90bb7b63c34751f4c495e0
ID 418 gen 8739 top level 305 path rockie/btrfs/subvolumes/b54b867d760328df6f7aca9934ddbbb5b2afebbbd9e228d86bede93324bcd0d2
ID 419 gen 8739 top level 305 path rockie/btrfs/subvolumes/fe5a39fcbbb23a05a3478944d5ad5143b01d0b63362d935c86c03a9a38fa3006
ID 420 gen 8739 top level 305 path rockie/btrfs/subvolumes/2b3b8ebd68c3baeb685d76e1f87ccd667b43ee7b6587a3beff4797ca70321bf1
ID 421 gen 8739 top level 305 path rockie/btrfs/subvolumes/86c9daa3d5aa144423daf15d87bd20a2e9f133903893f7178871751f0c96051e
ID 422 gen 8739 top level 305 path rockie/btrfs/subvolumes/fd9afcfa5754be3fa26d6a811717661e4cf7c42163216b8e2e076729b5397429
ID 423 gen 8739 top level 305 path rockie/btrfs/subvolumes/cd8ea80e21c405a5a3db583d91f8d459a12f1dfb0a912af413cf52eca9b18bf1
ID 424 gen 8739 top level 305 path rockie/btrfs/subvolumes/ebea89404d903a8fdbb8ae6ecc18e1a6cb63af0d4821b87385854310741b2679
ID 425 gen 8739 top level 305 path rockie/btrfs/subvolumes/595cc965de9c2d4b2d909a2663d7f34eb3659a50cfab04455b5408883a2d0e4c
ID 426 gen 8739 top level 305 path rockie/btrfs/subvolumes/68a23a078a69b225107bd75a3f53e4c10b5cc2e22a1bb9911c6666a0bd938734
ID 427 gen 8739 top level 305 path rockie/btrfs/subvolumes/5c873fdd5c4eb8b0b4ec43b0e52620a8ced984675949132789870b3789d6f236
ID 428 gen 8739 top level 305 path rockie/btrfs/subvolumes/8f201c360d8a0fba5fd9282814484f0709567aa4b7e34755855419c0de27f2cb
ID 429 gen 8739 top level 305 path rockie/btrfs/subvolumes/cd86ae9d800d87140d405637e7173562c6a6b7edf9175c7d47bc8517c1f5bf04
ID 430 gen 8739 top level 305 path rockie/btrfs/subvolumes/5b8f60cebbfc4707e64aa1ab8904609f9fc02bb0e64713aca3aee0d8304a5772
ID 431 gen 8739 top level 305 path rockie/btrfs/subvolumes/de7e8227bd117ff79ae1a40363386324a3287fb9d3f1e447236553292b827de8
ID 432 gen 8739 top level 305 path rockie/btrfs/subvolumes/aaf040aefaa146f4df48f219313dc0b5cdc1087d7b187b544321ea9cd6318b94
ID 433 gen 8739 top level 305 path rockie/btrfs/subvolumes/6105b320650ac2a542b0d76ab36ed7afef8a4f7b26ea60072b365259692bfc53
ID 434 gen 8739 top level 305 path rockie/btrfs/subvolumes/d798e6bba2c8187ed3854ffe40230e4800ebbe6c87538445a3896544f3c778d9
ID 435 gen 8739 top level 305 path rockie/btrfs/subvolumes/67dd3e1c209bcb1e32bf8f5be244034a4b995dc15d1e224c7fdae45716286087
ID 436 gen 8739 top level 305 path rockie/btrfs/subvolumes/2fe8d8fa7328657a6f4671c343edfae6589c3806c45ec4c02a92e985f93880c5
ID 437 gen 8739 top level 305 path rockie/btrfs/subvolumes/4ff7b30179589afc5a573693e4983a161744bcae4c9fb52de3b6251400b4234c
ID 438 gen 8739 top level 305 path rockie/btrfs/subvolumes/4dbe65675582ed6b8d92a37f5b0bfd20ee3a1c10ea6b680e33e164a5e01a418c
ID 439 gen 8739 top level 305 path rockie/btrfs/subvolumes/11c42258d370234968cb945cb6391ed87e62aabd235ff0556409cb952f0562b7
ID 440 gen 8739 top level 305 path rockie/btrfs/subvolumes/88d198fd8bb7e679e66748e2c4250d1d9f8028be2965b3646fb93d4bf4ffe7ba
ID 441 gen 8739 top level 305 path rockie/btrfs/subvolumes/4bd78b439d1e9d5e74f290d20ef95103f5e107c55651d96e2cdd6dae0f88f51a
ID 442 gen 8739 top level 305 path rockie/btrfs/subvolumes/242debf8ff0ed3dbb422cf46ffe418766336a5318eb69696ebc508dba8a77faf
ID 443 gen 8739 top level 305 path rockie/btrfs/subvolumes/e180e912767f13b2bdd0e04580e76e9fb09d94e28978e0fb82e540d387a3fd98
ID 444 gen 8739 top level 305 path rockie/btrfs/subvolumes/bbe115df1d182f39f1c4410b08d091d95fca8f93fe2efdc9fcd3b810cfee6096
ID 445 gen 8739 top level 305 path rockie/btrfs/subvolumes/2f91ab7976a3b582a241fd5d6c6708460f5a90e4f70b94dfee062410e878dd03
ID 446 gen 8739 top level 305 path rockie/btrfs/subvolumes/7b386e1fe6bd39a53fa46dda60f85e753d10b85947171ed4d0a0d6e9879bcf0c
ID 447 gen 8739 top level 305 path rockie/btrfs/subvolumes/c6bcd69c323f2c2ccb7e3cf81e3588608073114945b5866a0593b5d7ebcd9903
ID 448 gen 8739 top level 305 path rockie/btrfs/subvolumes/b71d386724b49ff6790f84b5b8272b701ed7219f3eccc82a82c7f25efea8b876
ID 449 gen 8739 top level 305 path rockie/btrfs/subvolumes/d9d685d437e190de31a9bd999fcd27961b8bfdd7d5fd2119e27c5e91e79590a7
ID 450 gen 8739 top level 305 path rockie/btrfs/subvolumes/bcbbdcbc2c76f7f8f1757c9b372152d94f4a8b507d30bfb7f3f241baf9f4e99f
ID 454 gen 8733 top level 305 path rockie/btrfs/subvolumes/6d43385453c17860a00ad19da477d997c20541aa1b53ddbbcf938ff11d4dc876
ID 455 gen 8733 top level 305 path rockie/btrfs/subvolumes/f316f43cf1fc7b329dea0b3838f6adb23cd734ef7d401377ec4546672615dbbf
ID 456 gen 8733 top level 305 path rockie/btrfs/subvolumes/60b5b5ed2861901c83c74a9b75f59cefb22b0ac0edc3ee97192adc5b7f47bd5d
ID 457 gen 8733 top level 305 path rockie/btrfs/subvolumes/3a70f5f43fc66018b59cbd1893e2ebdb3d080c93fad78556ad59a205e958c654
ID 458 gen 8733 top level 305 path rockie/btrfs/subvolumes/d6b66e921900e51d6f91550be9886a12d9978b4344edab4f166e298dc5b77f83
ID 459 gen 8733 top level 305 path rockie/btrfs/subvolumes/c2c2968c37a1c078d09e7b2bccd9e590086fe23ca2bcfbc19fb6b2c304bd2111
ID 460 gen 8733 top level 305 path rockie/btrfs/subvolumes/10ada1eb7baa68c22ad390321fae300f27591e6e432af655734d46f1c8e2c090
ID 461 gen 8739 top level 305 path rockie/btrfs/subvolumes/89fc5d4f80a0c9bd4a4b395d9167187d75411b5ba0293fe806daa5b8b1c34f09
ID 462 gen 8739 top level 305 path rockie/btrfs/subvolumes/6c02ecbd6c866edd4d48ea512787e3a1f52ab04f7d8c1b9c2ec18b80a4618de3
ID 463 gen 8739 top level 305 path rockie/btrfs/subvolumes/d4f0658847173c11f8164afc15a7f57587a39c23776e211fb82ff7f068c1e1ea
ID 464 gen 8739 top level 305 path rockie/btrfs/subvolumes/657926c9f8e42fa7bc1095f159add48cdf47e85e39c4a216e3663689f282a200
ID 465 gen 8739 top level 305 path rockie/btrfs/subvolumes/43ea65817c1e22787fcdb36a4d672719ed33efcdc8e48b3703bdf669de975328-init
ID 466 gen 8739 top level 305 path rockie/btrfs/subvolumes/43ea65817c1e22787fcdb36a4d672719ed33efcdc8e48b3703bdf669de975328
ID 475 gen 8739 top level 305 path rockie/btrfs/subvolumes/793f6bcee0d45e3ab20f229b2f10618e87f12abd9d40a16b079bfadffdc8ec32
ID 477 gen 8739 top level 305 path rockie/btrfs/subvolumes/62d7747327f386d4322542d57b58218fe06035ae7466941c87da8a7d3cbb585b
ID 478 gen 8739 top level 305 path rockie/btrfs/subvolumes/e99ad4b047dd4e95125c74066423b88af42d753602f81fd95901511bd8b86981
ID 479 gen 8739 top level 305 path rockie/btrfs/subvolumes/a1925a338b5e52174ed438941bbc7ab0188ae06a501c2ea92f08d1ec88773deb
ID 480 gen 8739 top level 305 path rockie/btrfs/subvolumes/8092f5a180011044a250314c134c98b506b7fd427177be8e094379ac35619353
ID 481 gen 8739 top level 305 path rockie/btrfs/subvolumes/43c94193c75c8ec3f946a1cbfaac5cb71b254dfd354171dc795341db85fc1d4f
ID 482 gen 8739 top level 305 path rockie/btrfs/subvolumes/d682542e1add6dad4390d90bc17baa09ede9d0e11b41b5893047566a886afa61
ID 483 gen 8739 top level 305 path rockie/btrfs/subvolumes/758b733543d4c33c3857c96b60ad55df94300c605aa0e3ba07a850a2a4702417
ID 484 gen 8739 top level 305 path rockie/btrfs/subvolumes/3d5cb7b3a2621a89daf4163e9bdc42f0a7f36070024d6d598eb361083484cce6
ID 485 gen 8739 top level 305 path rockie/btrfs/subvolumes/6fb2ef26c381ec0569fd56f5cad066d4de1925015ad220112544df0b85c9f542
ID 486 gen 8739 top level 305 path rockie/btrfs/subvolumes/b5a9b8dd14d4d91432d449c2d60ad04d9e067d0fe64b2ac406b14baf988a49b1
ID 487 gen 8739 top level 305 path rockie/btrfs/subvolumes/98ac9ad84f091b46892c689b1cf80b6ac4f8e3c1965f5e25b725caba82a03961
ID 488 gen 8739 top level 305 path rockie/btrfs/subvolumes/cc67a890eec07bc9cfbe18cf0d82cc2ba7fef5d31ffff4f9640c2fbf773425ff
ID 489 gen 8739 top level 305 path rockie/btrfs/subvolumes/52ef619bddd016a699a1c998b1a8d48284aae66c2bf11539d50d93e728b1c02c
ID 490 gen 8739 top level 305 path rockie/btrfs/subvolumes/dcf8f1e7083cffbfa00d23973dc1e3b56feac152c44891de693ff886c483ccb7
ID 491 gen 8739 top level 305 path rockie/btrfs/subvolumes/ac9f4372334762f758abc1cf3d53aa6ac7849bc8db4912250f21bdbf4957283b
ID 492 gen 8739 top level 305 path rockie/btrfs/subvolumes/9a153ac5ba7079b9f5171b9aee526a9701a7d3ce508e304054fa51dcef5d669b
ID 493 gen 8739 top level 305 path rockie/btrfs/subvolumes/d679e270ece8850ac9f1bdf4d345adc31cf3295ca6d794a8a967a52786dc9d72
ID 494 gen 8739 top level 305 path rockie/btrfs/subvolumes/14c39ab58c837bab461ccc02c45200bcc3bbdb17e0a5513efbf1b81d8a1387d5
ID 495 gen 8739 top level 305 path rockie/btrfs/subvolumes/8d63b5eb268ecd5db34871bcde7630c85cb51effc61a54c633908b53c9766a48
ID 496 gen 8739 top level 305 path rockie/btrfs/subvolumes/1611bb54d18798762ec35fb5c38ae027ffbe6552115ddb7f5864325b928dbff5
ID 497 gen 8739 top level 305 path rockie/btrfs/subvolumes/65296ff04f60d2cae8530c124e43672da66fbf0858d3213bcb56d9d3b05678b7
ID 498 gen 8739 top level 305 path rockie/btrfs/subvolumes/dce0768c16f872439a8118f4f0100e267cdd4127fedfc98e75d6a62ed24c796a
ID 499 gen 8739 top level 305 path rockie/btrfs/subvolumes/a44e66dc34457c7ed18830639d9cebf372363c0754c9b724ae246d5a40b29242
ID 500 gen 8739 top level 305 path rockie/btrfs/subvolumes/fdf9a2e3b31b0fb278f811cdd60d671ecedc19fa264a5e575890a57f206bcae4
ID 501 gen 8739 top level 305 path rockie/btrfs/subvolumes/1d69976605a90e1c456bb8bd06067020c029d94ca93e7190bdbf9de9326f9ac5
ID 502 gen 8739 top level 305 path rockie/btrfs/subvolumes/89f5bf6c890a242a3cab5ca2281117c05ce065f65675538f4a72eddcdace3f90
ID 503 gen 8739 top level 305 path rockie/btrfs/subvolumes/0e98340944adf217d70c30a15d0d8d862a465eb74225e01151f679645c012a11
ID 504 gen 8739 top level 305 path rockie/btrfs/subvolumes/17162afc832c8356374f1b276ea1cd6bc10e720af790380fa733842bb70b1227
ID 505 gen 8739 top level 305 path rockie/btrfs/subvolumes/c1ee368d3d0681bd6520e03ec9b5a2c1c0b1163d6d772397573a16d3d77c27a2
ID 506 gen 8739 top level 305 path rockie/btrfs/subvolumes/c9ad2416ddb73ba763580bf715cbbf2dd34ef621bb85a2a95d984333b7904d29
ID 507 gen 8739 top level 305 path rockie/btrfs/subvolumes/1b99cd6cab6b0448349ff9537bb8a10d2bb7c34d3e921dd74a39a92bdf23fa15
ID 508 gen 8739 top level 305 path rockie/btrfs/subvolumes/2ad5daad617bfab1995709983d528f65744dfddf4b55f70304d6956bb2a863f3
ID 509 gen 8739 top level 305 path rockie/btrfs/subvolumes/d49ae01593a6fdcda79465dbdedda583ba0a2bc0fa8a37d5aafe6790fcfe2a9f
ID 510 gen 8739 top level 305 path rockie/btrfs/subvolumes/7bc2736e1a3a213080a48602b496d2eb67fa32dd374897df28745e68aa6b70f5
ID 511 gen 8739 top level 305 path rockie/btrfs/subvolumes/f2ef59029ac8fd2bc255c8acdc5ed021d4f7c53d3fc07783ad84d80eb915ed52
ID 512 gen 8739 top level 305 path rockie/btrfs/subvolumes/ef4d3f872efabb5200caa4c33292e714987c37faf2b4f43fd428ccf8e2115668
ID 513 gen 8739 top level 305 path rockie/btrfs/subvolumes/5f5db7d84abd09e801af73e1fa0c1986902f4a6ef56f9e1a3ef7a5b595ce9ebf
ID 514 gen 8739 top level 305 path rockie/btrfs/subvolumes/65ed6e78a59906fcb03a99102cc289b8278a9aabfa485bad058ae80cd8925f18
ID 515 gen 8739 top level 305 path rockie/btrfs/subvolumes/6bac9c88a8b1b221f26a0f4185b5eb7f70215d982928c24c8c09b5e0193e594e
ID 516 gen 8739 top level 305 path rockie/btrfs/subvolumes/6ec4430eda3acc7000df79cd584a8e8fd89e5999916046133c39bd3984909e81
ID 517 gen 8739 top level 305 path rockie/btrfs/subvolumes/6aa719a14e7756e18279e313820b08663d9a4f8a0f0ba9341e8c8da313550dc1
ID 518 gen 8733 top level 305 path rockie/btrfs/subvolumes/df8f0d7daa7fc188a8da48763d0afc200ba971ced15657c0757a6d845e87d20a
ID 519 gen 8733 top level 305 path rockie/btrfs/subvolumes/111e7fc29d05810e2062641d18ac029e51ff9ec84be050e9ce36f3f5dc987ba4
ID 520 gen 8733 top level 305 path rockie/btrfs/subvolumes/9c7fcbfe2996f1f132ff01ad9eef44057a7226af4d87462dddf966e61b934099
ID 521 gen 8733 top level 305 path rockie/btrfs/subvolumes/c442fa7a421d59d46776ad08e02ac3a896549a6a1ae9cecab29f39fe2ec2c593
ID 522 gen 8733 top level 305 path rockie/btrfs/subvolumes/e3c89de5544457890d7df5ea60fba9d556b277cd3d02374b2e7c0914c2581b13
ID 523 gen 8733 top level 305 path rockie/btrfs/subvolumes/94fc5c7fbfd3d3c17b249251c8dc4c2fbd496f24139becd53242750bfebaabfe
ID 524 gen 8733 top level 305 path rockie/btrfs/subvolumes/9e09a17c5ffaa6634fd6648af0ee1b8f766a949da42a550c6cecb6a7309dff8a
ID 525 gen 8733 top level 305 path rockie/btrfs/subvolumes/6a5f5fcc82ff67c53eabb7a00df72858d939d8394ba87f36b524163734ace461
ID 528 gen 8733 top level 305 path rockie/btrfs/subvolumes/a961495a8a5cc75f00725147caec6e50b0c5d92c570faf7d8f859fd0ae22b04b-init
ID 529 gen 8744 top level 305 path rockie/btrfs/subvolumes/a961495a8a5cc75f00725147caec6e50b0c5d92c570faf7d8f859fd0ae22b04b
ID 530 gen 8739 top level 305 path rockie/btrfs/subvolumes/49604180c4b435600490160fa278ff2b3980f90315b7d01fa28a9d0f89a3411b-init
ID 531 gen 8739 top level 305 path rockie/btrfs/subvolumes/49604180c4b435600490160fa278ff2b3980f90315b7d01fa28a9d0f89a3411b
ID 535 gen 8733 top level 305 path rockie/btrfs/subvolumes/febd0c6e80cde15bab9b2059f70034b9680d32de10c4a48c3414ab6b147e0cad
ID 536 gen 8733 top level 305 path rockie/btrfs/subvolumes/6991cffdcb5d14a6de45f1c07bd65d1f0336258aa9a50fa07650627297994419
ID 537 gen 8733 top level 305 path rockie/btrfs/subvolumes/0d6b55164e2b757bea39eedbdd310e37208e97a9b144358b5fd3ec708bb94158
ID 538 gen 8733 top level 305 path rockie/btrfs/subvolumes/34f75279060759bd262220a62763bc5ee4e884c4518e339c139c41378ef72eb5
ID 539 gen 8733 top level 305 path rockie/btrfs/subvolumes/6a95109bdb8f61aeec6b29e6f7a4675fccc96a93d7afde861c8e07e5c5f25375
ID 540 gen 8733 top level 305 path rockie/btrfs/subvolumes/681e253bc29c47d0404f76f9d4b8587d70fee05c1b8ea9a301c2b1f4d40dd963
ID 541 gen 8733 top level 305 path rockie/btrfs/subvolumes/66218d3f63e639de1b467c33c364aaeaf7ddbee30af8732027e85ded118b2412
ID 542 gen 8733 top level 305 path rockie/btrfs/subvolumes/4ab0ad0233482497244aa451a80c026066567646c60ae5c7d1b9e18d01fd99f5
ID 543 gen 8733 top level 305 path rockie/btrfs/subvolumes/887d50b42179c39d6284e23c5bdb8ba6b8eafc63f22c8cb225e8cc0d5effd3bd
ID 544 gen 8733 top level 305 path rockie/btrfs/subvolumes/a1bd321815a0e8a44940361e32d3c66e7fb4b91aea00f6a538d87b6b50399ab6
ID 545 gen 8733 top level 305 path rockie/btrfs/subvolumes/83a20d74e61b13a5f6f4667ad5e074d20055dea8bb550ed37275efac653a5851
ID 546 gen 8733 top level 305 path rockie/btrfs/subvolumes/f70b2250913dce90b52c7d5ca81a023edc065045daa6becb46c75b0e75ea179c
ID 547 gen 8733 top level 305 path rockie/btrfs/subvolumes/b89ca64bd06098273fb791b8f0a33c64b58a0dbb2689b91ac822629d20780c33-init
ID 548 gen 8733 top level 305 path rockie/btrfs/subvolumes/b89ca64bd06098273fb791b8f0a33c64b58a0dbb2689b91ac822629d20780c33
ID 554 gen 8733 top level 305 path rockie/btrfs/subvolumes/822192ad3c2c06a4200e51c3f0ada1ffe0ded85d18e908eafa454f4e1445a98a
ID 555 gen 8733 top level 305 path rockie/btrfs/subvolumes/42a95ae9f34139a246b90e8798fe156e223da119ce6413ae5b3795aa8edfdf2f
ID 556 gen 8733 top level 305 path rockie/btrfs/subvolumes/04896b5565560a8180df006fb1791dba6c17a8091342004a51d85ac305bd403a
ID 557 gen 8733 top level 305 path rockie/btrfs/subvolumes/34b99f9323a55dce02bbc97080583c92002957c7b5d7fdb35159c9f85dccdfb4
ID 559 gen 8733 top level 305 path rockie/btrfs/subvolumes/e714d762f67c7de57b1eae47b3378aa3e3cf9e8f549f07c3f9bff22688c22a52
ID 560 gen 8733 top level 305 path rockie/btrfs/subvolumes/571083fc65ff9bd2a5b22d0e10da340f216dd0166db0cdbdae88a9a03239da47
ID 561 gen 8733 top level 305 path rockie/btrfs/subvolumes/67346673d811b31ee136f38069761bee1623889da17f53383ff972edc72873d0
ID 576 gen 8724 top level 305 path rockie/btrfs/subvolumes/044ffdf80f709b5e61fce241c616078ea39ce742c1133fac8c7b9aed802f441a
ID 577 gen 8724 top level 305 path rockie/btrfs/subvolumes/9d6be9c04d1ce7a717d2e6fe0155b16bac54d5c886289fb9c128ef211742f1cc
ID 578 gen 8724 top level 305 path rockie/btrfs/subvolumes/c5f9d764ba6f7fa8fc6b0c99bb5fc0b32bf03269634e3a614153844f618c6e2d
ID 579 gen 8724 top level 305 path rockie/btrfs/subvolumes/a8180f5366b6eb4e91d2ffd5fa6ea0849a5862e290ac0d4e84a54b9d46962695
ID 580 gen 8724 top level 305 path rockie/btrfs/subvolumes/559c3755cb8a565286944dc244dd898644482ab4b111b6087661117baf5aae01
ID 581 gen 8724 top level 305 path rockie/btrfs/subvolumes/303812408057641712e9b3b9da68adf1351a8f08f4ca10da529307a6df93a170
ID 582 gen 8724 top level 305 path rockie/btrfs/subvolumes/ff4e5fd019b4d482f3692ba71cfbe2eceaffd378f6d2bdf3b5693c7ccf206aba
ID 583 gen 8724 top level 305 path rockie/btrfs/subvolumes/25326f908a0635e5286ac9a4843ec8f187e56d37cf3d43dc0491698d23f93c22
ID 584 gen 8724 top level 305 path rockie/btrfs/subvolumes/babad499d33b35311e42d39f24e4d364c0e7cfe1c06605d7954805d97e3b9bac
ID 585 gen 8724 top level 305 path rockie/btrfs/subvolumes/0873ec44594c6800da77e2ba433f3ea8192b2d88a49af3aa95ede2c013dec8b6
ID 586 gen 8724 top level 305 path rockie/btrfs/subvolumes/4e925fde490ae99b222d12c848350ea67e963dc668730b5240eaf436240578f9
ID 587 gen 8724 top level 305 path
So you had some Rock-ons (docker images) via Rockstor WebUI and some docker images via CLI/not with Rockstor WebUI, is that right? If so, now I understand usage miscrepancies: docker images via CLI â no tracking over Rockstor btrfs handlers â no db updates
My suggestion: if you need a new docker image currently missing like Rock-on, code it
Thereâs a nice how-to, everyone will take advantage of new Rock-ons and if you need help youâve only to open a forum thread (weâre really lucky, Rockstor has a cool Rock-ons contributors community)
Back to your logs, I say thanks: you helped find an unexpected behaviour (docker images snapshots not tracked) we (@phillxnet, @suman and me) must check!
Please confirm docker images via CLI so going to mark this âSOLVEDâ (well, not solved, but not Rockstor directly related â user mods via CLI vs normal Rockstor WebUI)
Mirko
Correct, I had some installed via rockons and some via CLI.
I can and will code it, Iâll see if I can find the guide? is it in your documentation?
Sure, please mark it as solved and thanks again for your prompt assistance!
Hi @kwetiaw,
here Rock-ons documentation:
http://rockstor.com/docs/docker-based-rock-ons/overview.html
Link to Rockstor Rock-ons Github repo avail in documentation
Thanks
Mirko
@Flyer Re your:
Agreed we have some things to look at here but also as I understand it docker uses btrfs snapshots internally for itâs âlayersâ so we may have a hard time meaningfully tracking all of these from the âoutsideâ. But as of docker version 1.13 there is a facility to âpruneâ unused elements:
docker system prune
The above also has container, volume, and image variants in place of the system option.
See:
And another niceness is:
docker system df
with a -v variant.
I.e. use dockers own facilities to clean up after itself.
Looks like something we should âbake inâ, or maybe have a âpower washâ button that runs âdocker system pruneâ with associated warnings and a tie in with uninstalling all Rock-ons or something.
Havenât looked into it but saw it go by in docker news.
Thanks @phillxnet, was checking code without thinking to docker itself!
All those snapshots listed on Rockstor WebUI made me think about a Rockstor real flaw rather then docker nature!
Mirko
